changing ign barrel
burnout
Post Sat Feb 24, 2007 9:45 am
as title says wonder if someone could tell me how to remove
the ignition barrel lock.
thanks in advance
E30 325i se
monkey
Post Sat Feb 24, 2007 9:58 am
if the key still turns its easy . there is a hole beside where the key goes push a nail or pin in there will release a clip in the housing and the lock will come out the key needs to be in the first or second position for the pin to line up if you have the new lock you will see wot i mean . if the key dont turn you will have to smash it out bit by bit . good luck
burnout
Post Sat Feb 24, 2007 10:10 am
i was afraid you might say that as i don't have a key.
lost them the day i got the car :roll:
E30 325i se
monkey
Post Sat Feb 24, 2007 10:15 am
bugger . i had to hammer mine not to bad just try not to damage alloy housing .
burnout
Post Sat Feb 24, 2007 11:18 am
got the old one out without shredding too much blood
is there a nack to put the new lock in?
E30 325i se
eko
Old timer
Post Sat Feb 24, 2007 11:22 am
burnout wrote:got the old one out without shredding too much blood
Assuming you havent damaged the housing?
Just turn the key in the barrel to position 1 and slot it in,job done :)
gazza
Post Sat Feb 24, 2007 12:16 pm
zone article on the articles section here is the link to make it easier
http://www.e30zone.net/modules.php?name ... hnlock.htm
Image design cab and now 325 touring
burnout
Post Sat Feb 24, 2007 3:32 pm
thanks for your help guys got it sorted
next time i won't lose the keys
E30 325i se
