i hate my e30 2day!!!
tbg
how do i change the drivers door lock barrel?
been trying to do it for 2 hours and haynes manuals are dogshit, i dont know why people think they are so good, they hardly go into any detail.
you cant even see....let alone get to the lock barrel, or feel it!!! even after taking the door to pieces, i ve stripped it bare and i cant believe bmw would be happy with this design. any help would be much apperciated. tommy
eko
- Old timer
There is a `horseshoe` shaped clip that holds it in place!
I use a long flat head screwdriver,lever against the door frame a flick it off
Admitidly it is a fiddly job
tbg
thanks ill see how i get on....... think ill do it 2mozorrow moring now tho as the light is fading
dazleeds
- old skool raver
www.oldskoolfantasy.co.uk
eko
- Old timer
10 minute job once the door panel is off!
Honestly use a mega long screwdriver and its a doddle to do
dazleeds
- old skool raver
been there many timeseko wrote:10 minute job once the door panel is off!
but i still hate em lol
cant get my arms in there no wayyyyyyyyyy
eko
- Old timer
Yeah,probably helps if your a skinny fecker like medazleeds wrote:been there many timeseko wrote:10 minute job once the door panel is off!
Worse part is getting the clip back on,sore finger time!
dazleeds
- old skool raver
dnt remind meeko wrote:Yeah,probably helps if your a skinny fecker like medazleeds wrote:been there many timeseko wrote:10 minute job once the door panel is off!
cant get my arms in there no wayyyyyyyyyy![]()
i'll have ripped up arms tmoro
ric325i
yeah done that one.......its just one of those painful jobs you wish you didnt have to do.
getting it off aint too bad but putting it
on takes some major patience!
Demlotcrew
I take the window mechanism out only a few nuts and bolts.
Andrew
Andrew
Chris-W
Lower window guide swings out of the way after removing just one bolt.
316eyes
Not up to your usual standard, Brian.Brianmoooore wrote:Lower window guide swings out of the way after removing just one bolt.
Which bolt?
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
The single bolt that holds it! Not much of a choice.
Pull the metal part of the guide down slightly and it will unhook from the top part. Then swing the bottom across and tuck it up into the winder mech.
SPADGE
At a guess i would suggest the lower one on the window guide316eyes wrote:Not up to your usual standard, Brian.Brianmoooore wrote:Lower window guide swings out of the way after removing just one bolt.![]()
Which bolt?
tbg
ahh lovely all done, lock replaced. needed to be done after some fecker tried to break into my car with a screw driver. also had a go at the boot with a crow bar i guess so i had to replace that aswel! all gud now tho. thanks ecko for the horseshoe explaination really helped me!. tommy
eko
- Old timer
No problem mate,glad you sorted ittbg wrote:ahh lovely all done, lock replaced. needed to be done after some fecker tried to break into my car with a screw driver. also had a go at the boot with a crow bar i guess so i had to replace that aswel! all gud now tho. thanks ecko for the horseshoe explaination really helped me!. tommy
