OBC - I can see the display faintly ....but
Z3I
no lights on buttons. Does this mean I just need the new bulbs? Will I then see display in daylight?
Yes, i think so! My car needs this doing also. For the display, you slide out the white backlight bar in the side of the obc which has two small bulbs soldered in (you can solder in new ones or white LEDs), or buy a complete unit from the stealers for around £22! The keyboard is lit by a twist-fit bulb in the back of the obc.
Getting the obc out is the tricky bit - held in by small hidden screws.
Z3I
Thanks, sounds hopeful.
If I take out the radio, should be able to get access I guess. £22 will be just about bearable. I can see it works ok faintly from the stalk..
tomtomiS
i paid £25 for my light bar from barons. loosen all the nuts enough and u may be able to get at the lightbar without taking the whole thing outta the dash. the display is lit by the lightbar and the buttons by the twisty bulb.
Here's a handy thread regarding this: http://newling.no-ip.com/rep/bordcomput ... licht.html
Z3I
Thanks Tomtom...I'll be giving it a go.....
It also helps to undo the glovebox restraining straps, allowing it to fully drop, then remove the small plastic trim piece to the left of the obc (allows you to get a small screwdriver in there to try and undo the screws holding the obc in place - you may also be able to reach the keyboard backlight bulb.) Also you can pull out the hazard warning switch and also removing the radio would help for gaining access. But it's a tricky job all the same!
tomtomiS
i did mine with no switches or stereo in place and the two screws removed from where the hazard lights/ hrw switches are. u can bend the panel a fair bit without it snapping. a good tip is to use a screwdriver with a nice snug fit so hopefully not end up dropping the screws
Z3I
Nice project job during Febuary though, when It doesn't see the road, unless its absolutely dry. It would be really nice to have this working.
now all I need to do is fix the small dents in my bootlid, and I'll be happy
Don't ever expect to see them again if you do!tomtomiS wrote:so hopefully not end up dropping the screws
Z3I
Reminds me of an old tip of always screwing up some masking tape under anything like the OBC, which has darknes under it from where nothing returns, when removong screws....
E30Mark
Is it just the button illumination that is out? there is a single 12V 1.2W lamp for the button illumination, cost pennies to replace. The display illumination is the hard to swallow £22+ bit.
PM for details
PM for details
You'll find it well worth fixing - there's some very handy functions on there such as fuel economy, outside temperature, stopwatch, etc. There's a small Phillips screw at each corner around the back. A bit of Blue-Tac on the end of the screwdriver is useful to avoid losing them.
This article might help:
http://www.pelicanparts.com/BMW/techart ... cement.htm
Fixed the keyboard backlight in my 325i today; it's possible to do it without removing the obc, by removing the plastic trim to the left of the obc and using tweezers to untwist the bulb (and putting in the replacement the same way).
