hit a kerb today!
caneswell
Post Wed Feb 07, 2007 9:31 pm
Sideways with the rear wheel.. . . . Well if you are gona do it do it properly!
Anyway, it has bent the wheel (see other thread). But i think it may have bent the suspension. Not had much of a look as its dark and cold. How easily are bits bent there? Where's the weak link? What is likely to need replacing?
lenny-d
Post Wed Feb 07, 2007 10:00 pm
a mate did the same in his and it was a new sub frame.
bigun wrote:sell my sport i'd rather f**k the dog :)
for sale one left kidney, high mileage, need slight bit of work, will p/x for front wings and rear qtr panels
Greeny
Post Wed Feb 07, 2007 10:09 pm
I also did the same in my last e30, managed to remove half of the spokes from my 17" alpina's. I had to replace the rear wish bone and drum assembly.
Gone but not forgotten.
('92 325i Cabriolet)
caneswell
Post Fri Feb 09, 2007 8:03 pm
how does one determine which bit is bent?
also where would I get trailing arms from?
Chris-W
Post Fri Feb 09, 2007 8:13 pm
If there's a weak point it's where the trailing arms mount to the rear beam. But the mounts are strong enough to bend the trailing arms before they do give!
2nd hand would be your best bet.
Post Fri Feb 09, 2007 8:15 pm
you must of hit the back end hard because they have been pretty tough in my experience! A trailing arm doesn't bend easily!
I bent bigtime a wishbone once, wish i had a picture of it, long before the zone was around!
bigdek
Post Fri Feb 09, 2007 8:36 pm
i did same a while ago this is my o/s/r/ wheel
win
Post Fri Feb 09, 2007 9:14 pm
I done the same but mine was the front, i had to get a new suspension leg and steering rack
