Could the blue sensor be at fault for not starting when warm? Starts first time
when really cold minus 3 this morning and had stood for 4 days!! Ten minutes later did not start for a good few seconds cranking about 15 seconds but feels
like hours.
Other suggestion fuel pressure regulator. Pump & relay both replaced.
Really would like some help.
Warm start problem
Blue temp sensor is prime suspect for any temperature related problem.
Leaking injector would also cause this problem.
bluesheenadog
Thank you Brian,
I will change thsi tomorrow weather permitting!!
If this is a six cylinder car, problems with the injector loom connector under the inlet manifold can give the same effect as a dud blue temp sensor.
bluesheenadog
No it's an '88 318i,
