Front Windscreen - 318is
Tizerhead
Post Tue Feb 06, 2007 12:13 am
Is this a possible do it yourself jobbie to change or is it best to go to the autoglass people?
If it is possible to remove window and replace with another what will i need and how should i go about it to make it m.o.t passable!
i eagerly await your replies :) thankyou
Chris-W
Post Tue Feb 06, 2007 12:18 am
It is a possible DIY job, yes. You'll need some patience, a lubricant and, in the absence a specialised tool, an old blunt flat-head screwdriver to get the plastic trim back in.
E30Mark
Post Tue Feb 06, 2007 9:12 am
And it's alot easier to do if the rubber seal is warm... do it on a sunny day, or just bung the autoglass chap £20 :D
PM for details
Post Tue Feb 06, 2007 9:36 am
E30 windscreens are easy as windscreens go. Requires two people though to do it safely.
Pull the locking strip out, sit in the front seats with your feet up on the glass and push to get the old glass out.
Biggest danger is to the paintwork when you try to refit the locking strip if you're not using the correct (£10 or so) tool. Easy to slip and gouge the paint.
Don't use washing up liquid as your lubricant - it contains large quantities of salt.
charlE30
Post Tue Feb 06, 2007 3:41 pm
I've also got to do this for the MOT, does the little clip (bottom centre) just pop out with a flat blade screwdriver?
BMW F31 335d xdrive
Chris-W
Post Tue Feb 06, 2007 4:09 pm
Yes, but be warned that it's very soft metal - be careful not to bend it.
charlE30
Post Tue Feb 06, 2007 7:21 pm
Cheers Chris :)
BMW F31 335d xdrive
