Ok car was running like a dog idle lumpy mpg crap rough running. Did compression check low on 1 and 2 exhaust leak on 6 and inlet manifold leak on 6. So removed head replaced headgasket and inlet manifold gasket and exhaust gaskets all good did compression check all identicle 12.5 on the gauge across the board excellent. Start it up lumpy idle smells rich stutters up to 3500 ish then fine. Ok so i change filter and plugs clean the ICV now stable idle 700 doesn't rise or drop but lumpy and the same running issue up to 3500. Now changed blue sensor and brown cleaned all connectors tps checked on multimeter checked injector loom have cleaned all connectors and sensors, still same running issue.
Change:
blue and brown temp sensors
rotor arm dissy cap plugs
thermostat
inlet gaskets
exhaust gaskets
head gasket and cam belt
I'm now looking to change AFM and leads but these are expensive and i would be gutted if they made no difference and also FPR.
Like I say after 3500rpm drives like a beast. I am situated in Cardiff does anybody have a 325i in the area I could try parts with? Or any other thoughts on what can cause this. I feel it is more of a fueling issue that ignition but i could be wrong.
