325i electric window switch lights
gavo
Post Wed Jan 31, 2007 10:13 pm
I dont know if all e30's are like this or it's just mine but the electric window and sunroof switches stay illuminated all the time.And as i only use it 2 or 3 times a week im always goin out to a flat battery.
www.level-1.org.uk
Powering the UK underground dance scene with free internet radio streaming
Chris-W
Post Wed Jan 31, 2007 10:14 pm
You may have faulty door switches, ie. they don't know that the doors are closed. Whip 'em out, clean 'em up. Or replace them.
gavo
Post Wed Jan 31, 2007 10:18 pm
but the interior lights dont stay on just window switches
www.level-1.org.uk
eko
Old timer
Post Wed Jan 31, 2007 10:26 pm
Gavo,as Chris said,dirty/knackered door pins are probably the problem!
Clean and/or replace :)
gavo
Post Wed Jan 31, 2007 10:34 pm
ok will give it ago weekend then
www.level-1.org.uk
Post Wed Jan 31, 2007 11:01 pm
Wonder if the electric windows are OE fitted? Do the windows work with the ignition off? Ignition off and doors open? Ignition on only? Do you have another "switch" in front of the right hand window switch?
gavo
Post Thu Feb 01, 2007 5:13 pm
The switches are on eitherside of the centre console and yes they work with the ignition off and with the doors open not to sure if the sunroof does the same will have to check that.There is also another push button switch up by the hazard switch for the windows but not sure what it does.
www.level-1.org.uk
Post Thu Feb 01, 2007 8:17 pm
Brianmoooore wrote: Do the windows work with the ignition off?
Ignition on only? ?
The switch by the hazard switch is the missing switch from the console.
It's fitted there as standard on cabs.
Is this an early 325?
Anyone know if the cut out was fitted next to the hazard switch on early 325s?
Regarding the door pin switches, they should be two switches in one, and it's possible, though unlikely, that the interior lights could work properly and the windows not.
Unscrew the single screw that holds them in and pull them out. As soon as you unscrew the screw they lose their earth, so if the lights in the switch go out, these are the problem.
eko
Old timer
Post Thu Feb 01, 2007 8:24 pm
My window cut off switch is located near the hazards too,think its just cause its a pre facelift,mine are factory fitted!
