Does anyone know by what amount, and over what range, the AFM should alter the voltage? I'm trying to test my AFM (doing the best I can with a digital multimeter) but there seems little difference between fully closed and fully open (assuming I'm going it right: the AFM is the usual way up, and I'm guessing that pins 1-4 run left to right)AFM should be switched off by the throttle position switch at idle, so check out the TPS.
Correct way to check an AFM is to apply a fixed voltage, of say 5V, across pins 3 and 4 of the AFM, and monitor the voltage across pins 2 and 4 as the flap is opened.
The voltage needs to be monitored with an analogue voltmeter or preferably an oscilloscope, and should be a smooth transition with no spikes.
