Any 323i Experts Out There???
StuBeeDoo
Post Tue Jan 30, 2007 8:50 pm
All the tech info I can find lists early 323i engines as 138bhp. The same info lists late ones as 150bhp.
Where did the extra 12bhp come from?
I've checked ETK and the 'head, camshaft and pistons are the same right through.
Is it something to do with fueling or ignition?
I'd always thought it was increased compression in the later cars.
Any light shed on this appreciated fellas.
TIA
Stuart.
dazleeds
old skool raver
old skool raver
Post Tue Jan 30, 2007 8:52 pm
uh ohh your thinking 323 again arent you stu winkeye
www.oldskoolfantasy.co.uk
StuBeeDoo
Post Tue Jan 30, 2007 9:10 pm
dazleeds wrote:uh ohh your thinking 323 again arent you stu winkeye
It's never gone away Daz mate! :lol:
Post Tue Jan 30, 2007 9:18 pm
If my memory is correct
the very early ones were 139 brake, which was silly as the 320 was just as fast and alot cheaper! so pretty early on BMW added a bit of omph to the 2.3 to widen the gap in performance, better cam and a few other bits.
Most 323's that are left are 150 jobbies very few 139's were made, these 139 cars would be X,A platers
E30Mark
Post Tue Jan 30, 2007 11:07 pm
My B plate ('85) 323i was a 150Bhp model did they ever make a 139bhp E30? i thought the lower power engine was from the E21's.
PM for details
Post Tue Jan 30, 2007 11:13 pm
i'm sure they did when they introduced the E30 it didn't stay in production long though
kidsinister
Post Wed Jan 31, 2007 11:51 am
E21 323i was 143BHP.
ed325i
Post Wed Jan 31, 2007 3:38 pm
Dont know what mine is how can you tell 139 bhp or 150 bhp ?
but by the way it goes I would think its 150 bhp.
Theo
Post Wed Jan 31, 2007 3:40 pm
They were 139 bhp up until 09/1983. :cool:
ed325i
Post Wed Jan 31, 2007 3:52 pm
Mine is a 08/1984
StuBeeDoo
Post Wed Jan 31, 2007 4:30 pm
Thanks everyone, but the question is where did the extra bhp's come from???
Post Wed Jan 31, 2007 6:18 pm
does it matter?! it's still slower than a 2.5 :D
StuBeeDoo
Post Wed Jan 31, 2007 6:22 pm
Simon13 wrote:does it matter?! it's still slower than a 2.5 :D
Simon, f**k off with your smartarse comments.
I asked a question and if you don't have the answer butt-out.
Can't you get it through your stupid thick skull that not everyone is interested in 325i's?
Why don't you start a 325i+ Zone and leave the rest of us to what we want.
ed325i
Post Wed Jan 31, 2007 6:32 pm
Its only got 1 part number for the ECU but I am sure there was 2 diffrent ones :?:
Post Wed Jan 31, 2007 6:33 pm
get f**ked, last time i help you out. i thought you had humour :?
kidsinister
Still making friends I see, Simon. :wink:
Post Wed Jan 31, 2007 6:39 pm
right last time i help you stewart
139bhp M20 in production for a year
then onto 150bhp, achieved through a different cam, inlet manifold diameter and length changes and a 2 stage distributor
Post Wed Jan 31, 2007 6:40 pm
ed325i
Post Wed Jan 31, 2007 7:04 pm
I want to know how much bhp you can get from a 2.3
I am thinking about a cat cam
2.5 inlet maifold and TB
got the 6 branch
Later injection / ign system so it can be mapped (173 ECU)
2.5 valves in the 2.3 head.
StuBeeDoo
Post Wed Jan 31, 2007 7:11 pm
Simon13 wrote:right last time i help you stewart
If you thought you know the answer, why didn't you state it instead of being a tit?
On my (2005) copy of ETK, the cams are all the same and I can only find two different distributors. Everything else I can think of that would make a difference to the power output has the same part number from day 1 to the end of production. That's why I asked the question. :mad:
StuBeeDoo
Post Wed Jan 31, 2007 7:15 pm
ed325i wrote:I want to know how much bhp you can get from a 2.3
got the 6 branch
If you go for a 282 cam Ed, I can't see why you wouldn't see over 165, maybe even 170.
Theoretically, it should be torquier than the 2.5 because of the longer stroke.
Post Wed Jan 31, 2007 7:23 pm
your welcome
StuBeeDoo
Post Sun Feb 04, 2007 9:49 am
OK, I think I've cracked it.
According to the Mahle website, there are 3 different piston versions:
9.5:1 comp = 139ps
9.8:1 comp = 143ps
9.8:1 comp = 150ps
bigkev
Post Sun Feb 04, 2007 10:09 am
essbee i dont know if you can get an alpina cam anymore but my C1 is rated at 170hp, which to be honest i find hard to believe as i cant see a cam giving 20hp alone, i took the head off a while ago and there was next to nothing done on the ports etc , I gave the head a proper flow and blueprinted the manifolds redid all the valves new leads dissy cap etc and its running loads better now (a lot quicker than a 325i :P ) pulls strong right up to 7500rpm .Personally i wouldnt bother with the valves from the 325i as its a lot of work and money for very little or no gain (you also might loose some midrange)
I dont know if Alpina did anything to the bottom end as far as pistons go though i did notice my pistons were convex
Get it ready for the POD and we'll show these 325's the way forward winkeye
StuBeeDoo
Post Sun Feb 04, 2007 10:55 am
The factory fit cam is a 252. I read somewhere that the Alpina cam is a 268. I can't make-up my mind on cam spec yet, I haven't ruled-out using a standard one. At some stage, I may talk to Kent about doing me a one-off.
I know I'll be using 9.8:1 pistons and leaving the 'head totally standard.
I'm not bothered about top-end power, I couldn't care less what the bhp figure is (although I may get it dyno'd just for curiositys sake).
What I'm ultimately after is as much mid-range as possible without going below 30mpg touring consumption - that's why I won't do a 2.7.
kidsinister
Post Sun Feb 04, 2007 1:35 pm
According to the 'Alpina Performance Portfolio', for the C1:
"The combustion chambers are made fully hemispherical... and different, reprofiled valves are used. Pistons are also specially made by Alpina*..."
The cam is 268.
*Another article states that these are Mahle.
Post Sun Feb 04, 2007 3:38 pm
the 2.7 engine route properly done is the only M20 engine bar the standard eta engine that will do 30mpg and not be a roadblock
Alpina always fit higher comp mahle pistons they are also lighter normally too
bigkev
Post Sun Feb 04, 2007 5:56 pm
i can believe the pistons are custom judging by the amount poking out above the block and it loves to rev although without a limiter you've got to be carefull , as far as the 'reprofiled valves' goes i'm not so sure.At the end of the day its still a 325i beater
StuBeeDoo
Post Sun Feb 04, 2007 6:10 pm
kidsinister wrote:Pistons are also specially made by Alpina*..."
I'd be very surprised if Alpina make their own pistons. More likely they're made by Mahle to Alpina spec's and only supplied to Alpina.
