differential
mrgtsx
ok guys turbo conversion is underway now im in hunt for a diff. i doubt the stock 320 will hold so i need one that is abit stronger. what do you guys suggets ive heard alot of good words about the 5 series diff
The only diffs that will fit straight into an E30 are the small case (that you already have) and the medium case from the 325.
The medium case diff is very strong, but only you know what sort of torque and power you intend to put through it.
The large case diff is extremely strong and can be fitted with appropriate mods to the rear beam.
mrgtsx
so my best bet is a 325 diff. well it wont be going over 200rwkw and torque wise not 100% sure on it thanks
There are diffs from other BMWs with the same medium case internals, some of which can be fitted with enough fabrication.
Diffs from some smaller engined E28s are medium case, and fit E30s with a change of rear cover and output flanges. Diffs from E36 compacts and Z3s are fitable as well.
