e30 wiring loom
dn808e2
Post Sat Jan 20, 2007 10:42 pm
Hi
are the all e30 have same wiring loom all around , electrics, dash board,
exept engine i should immagine.
why i'm asking , the point is that my car has 17 years now , so i was thinking to change wirinig loom in dors, dash board , torpedo, fuse box too.
can i use it from 325 320 for example? or it must be e30 m3 wiring loom.
many thanks
kam-325i
Post Sat Jan 20, 2007 10:49 pm
I should imagine that you could use around 90% from a normal E30....but the M3 aint a normal E30..... !!
Post Sat Jan 20, 2007 10:56 pm
E30 main car looms come in two flavours: check control version and non check control version. Also a little variation at the back of both for the touring looms, and, of course LH drive and RH drive.
Not familiar with the M3 body loom, but I can't see why it should be any different except for the addition of an oil temp wire.
dn808e2
Post Sat Jan 20, 2007 11:50 pm
many thanks .
i had bad connection in my car drivers door , i 've changed wiring loom in door , but i took it from
RHD car driver's side , and it went to driver's side on my car, strange but it woreked ,
mirror's regolator is on the left on LHD but here in Uk it's on right side .
Post Sun Jan 21, 2007 12:13 am
New pins/sockets are available for the door plug and sockets. No need to change the whole loom, or hard wire through the hole in the connector provided for the purpose.
Locking/windows loom is (virtually) seperate from the main loom, and can be reversed in the car to suit LH or RH drive.
A1BMW325iSport
Post Sun Jan 21, 2007 12:20 am
i've hard wired all my door wiring on both doors. i removed the pins/sockets and put lengths of wire in correct colours through each hole and soldered/heatshrinked them all. jobs a good un.
i have couple of complete wiring looms in garage spare so i just pinched wires from that.
dn808e2
Post Mon Jan 22, 2007 7:52 pm
Thanks MEN :D
How can it be , i locked driver's side door and all around was locked , but when i lock the car from passanger's side all it lockes is passanger's side door and fuel lid
8O
