After sitting for about 4 days, it starts only after cranking a minute (or two..). The engine then splutters for half a minute, fuel smell from the exaust, and then runs fine afterwards. When tow-started, it starts almost immediately.
- When this happened, I replaced the main and fuel pump relays.
- Cleaned contacts, checked ground points
- Also checked all sensors with a multi-meter, read fine.
After a few occasions of this, and after the car started fine (for a change), it suddenly died about 1 minute after startup when driving slowly, downshifting to 2nd and completely refused to restart.
A road-side diagnosis showed that there was no spark neither from the plug nor from the coil. Started right up again after tow-starting.
- So I replaced the notorious speed and reference sensors
After this, it soon stalled again, again driving slowly, a minute after startup, when downshifting to 2nd. Wasn't able to diagnose it that time. Eventually got it tow-started (took quite a bit longer this time) again.
- so I replaced to coil
- ... and the ECU
Car didn't stall on me after that.. In fact, I was pretty much convinced the problem was solved. But now, after sitting for a few days....
I'm pretty much at a loss diagnosing this problem. The fact that it only appears after sitting for a few days or at random (cutting out), and (ofcourse) only when you really don't have the time to diagnose it doesn't really speed up the process.
Summarizing:
- replaced speed/ref sensors, coil, ECU, fuel relay, main relay
- checked and cleaned contacts (will do this again)
- if it runs, runs as normal, pulls strong, etc.
- took loads of bumpy roads suspecting a bad contact somewhere. doesn't cut out whatever I try to do.
- when it cuts out, or refuses to start, tach seems to track engine RPM, indicating that the ECU at least has power and a speed signal
- when it cuts out, it's just like someone cut the ignition. no splutter or anything, just dead.
- when it cuts out, there's no spark from the coil (verified once, will need to verify again)
- tow-starting gets it running again
- after cranking for a loooooong time, exhaust smells of fuel
- battery is a few months old, very strong, as it supports cranking the car for minutes..
I'll re-diagnose everything again ASAP, but for now I suspect I'm still not getting a spark from the coil during these long cranking sessions.
Anyone any clues? I'm pretty much at a loss...
