Does rain affect fresh cavity wax?
kevin316i
Post Fri Jan 12, 2007 5:03 pm
I sprayed some cavity wax in the bottom of the passenger door and left it a few days before driving, but the rain seems to have turned the originally brown wax white. Has the water emulsified the oils in the wax, or should I just ignore? The inside door liner hasn't gone on yet so I'm wondering if I should just wipe the bottom of the door out an reapply?
k130
Post Mon Jan 15, 2007 2:56 pm
Hi
I waxoyled my car about three weeks ago, when I sprayed it in it was roughly the colour of beer and three weeks later it has set to an opaque white wax colour (looks a bit like vaseline) and it has had no contact with water at all. I guess many of these products are the same so I expect its ok.
kevin316i
Post Mon Jan 15, 2007 3:14 pm
Thanks,
I'll leave it as is, and put the door membrane and card back this week.
Regards,
Kevin
kam
Post Mon Jan 15, 2007 3:29 pm
Just out of curiosity, where did you guys buy the wax from? Does it come in aerosol can?
Cheers.
Kam
E30Mark
Post Mon Jan 15, 2007 3:44 pm
Waxoil is great stuff, until it gets too hot... if you put too much in it can seep / run out in hot weather. In theory this is good, because it runs into all those hard to get places, but it can make a mess of your drive! Just be prepared from some seepage later.
PM for details
k130
Post Mon Jan 15, 2007 7:35 pm
Waxoyl is available from halfords, either as an aerosol spray or, if youre doing the whole car a big 5ltr pump spray.
Also it stinks if you use it inside...
kevin316i
Post Tue Jan 16, 2007 11:34 am
I tried the Waxoyl kit with the pump and thought it was the greatest load of sh*te ever. I warmed the can of wax as instructed but as soon as I used the spray wand it congealed straight away in the line and got blocked, after it sprayed out onto my overalls!. Think you would need a heated spray line and use it in very warm conditions.
I use Tereson cavity wax in aerosol tins and it is very convenient. Got a 2ft long extension for spraying into hard to reach areas. The disadvantage of aerosol is that the wax is thin and you need to build up a few layers. However, aerosol is very handy to use and no mess.
