Misfire at idle M20B25
Morat
Post Wed Jan 10, 2007 4:48 pm
My Touring can be a bit rough on starting - taking a while to build up to 6 cylinders and often misses one all the time at idle.
This never really bothered me since idling on 5 is still better than 4 :)
But I booked it in for MOT and it failed for emissions (way off, apparently) and for this misfire. The local garage are looking at HT leads which I would reckon to be fair enough, but they're not visibly damaged and the 6th cylinder comes in under load/throttle. Plugs are 3k old. Dizzy cap and rotor are 10k/12 months old. The car has had ICV/AFM/FPR/TPS replaced when we were trying to trace some rich running problems, sounds like I should have had it rolling roaded too :(
When I get the car back tonight I'll try disconnecting HT leads to work out which is the culprit. Not sure what to do after that...It runs low on the temp gauge (but still above the blue) and thermostat is one of the few things that hasn't been changed - it that worth a try for the emissions?
I'll try and get some more specific readings on the emissions result too...
Morat
Post Wed Jan 10, 2007 5:25 pm
It's never going to pass an MOT with the temp gauge in the blue, and shouldn't really have been tested, because it wasn't at normal operating temperature.
Definitely replace the thermostat.
Take out a plug and tell us what colour it is. Check no 6 plug as well; it's easy to damage that one or close up its gap when you fit it. Very much doubt if it's a lead fault.
320Touring
Post Wed Jan 10, 2007 5:40 pm
I know that my m20 used to stutter on 5 when cold-
replacing the blue temp sensor and the broken thermostat solved that issue- £18 all in for parts from GSF
as brian says, duff HT lead on an e30 is as rare as andyboy buying a round....
Morat
Post Wed Jan 10, 2007 5:42 pm
Ah, I should have listed the blue temp sender in the "replaced" list above. Still, it makes the thermostat look more likely. I'll get searching on how you replace this little git. Santa brought me a socket set for Christmas :)
(this could get expensive!)
320Touring
Post Wed Jan 10, 2007 5:45 pm
Morat wrote:Ah, I should have listed the blue temp sender in the "replaced" list above. Still, it makes the thermostat look more likely. I'll get searching on how you replace this little git. Santa brought me a socket set for Christmas :)
basic m20 servicing guide in the articles section covers this, and the coolant repalacement you'll do at the same time :wink:
Post Wed Jan 10, 2007 6:04 pm
Especially note anything it may say about airlocks when you refill. Monitor the heater output, and watch the temp gauge, or a cracked head may await you.
320Touring
Post Wed Jan 10, 2007 6:09 pm
Brianmoooore wrote:Especially note anything it may say about airlocks when you refill. Monitor the heater output, and watch the temp gauge, or a cracked head may await you.
just to reinforce this point!
Bleed it, then Bleed it some more. what you need is only coolant coming out the bleed screw.
Heaters to full heat and blower on full to push any air trapped in the heater block.
take a couple of hours and dont rush, jobs a goodun!
robsy
Post Wed Jan 10, 2007 6:16 pm
Interesting stuff - What do you do if the bleed valve head has rounded off?? How do you bleed the system after fitting a new thermostat then??
320Touring
Post Wed Jan 10, 2007 6:24 pm
robsy wrote:Interesting stuff - What do you do if the bleed valve head has rounded off?? How do you bleed the system after fitting a new thermostat then??
A crude but effective method is to leave the cap off the expansion tank, and park the car on a kerb so that the expansion tank is the highest point in the system.
run the car at idle and watch the air bubbles escaping from the tank.
I'd do this a couple of times to be certain sure. let the car cool down in between.
Post Wed Jan 10, 2007 6:51 pm
robsy wrote: What do you do if the bleed valve head has rounded off
Remove it with a pair of grips and fit a new one would be ideal.
You can loosen the clip on the hose where the bleed valve is and slide it nearly off to let the air out.
Similarly, to deal with the serious airlock at the back of the head, if you get it, slip the top heater hose nearly off the stub pipe on the bulkhead.
Fill the header tank right up before you do this in both cases.
Morat
Post Wed Jan 10, 2007 9:36 pm
Yep, found the thermostat bit in the servicing guide, and thanks for the advice on bleeding. The last thing I need is to crack the head!
Right, Emissions test results:
Hydrocarbons: 2546 ppm
CO: 0.87%
CO2: 11.21%
O2 4.91%
DC voltage 12.7V (hurrah!!)
Engine speed 0 rpm (?)
Engine Temp 0 deg C (?)
Corrected Legal Carbon Monoxide 1.08%
Lambda 1.113
So.. thats a lot hydrocarbons then?
Morat
Post Wed Jan 10, 2007 9:42 pm
The sheet of woe says "(misfire on engine) exhaust emits clearly visible black smoke during acceleration".
Well not particularly visible from the drivers seat, but who am I to argue. I'm sure there's no misfire on acceleration tho.
Morat
320Touring
Post Wed Jan 10, 2007 9:45 pm
Morat wrote:The sheet of woe says "(misfire on engine) exhaust emits clearly visible black smoke during acceleration".
Morat
tbh if the car was tested cold, and overfuelling horribly due to duff T/stat/blue sender, then overfuelling would produce black smoke on accel, and also a stutter as the engine is already too rich at idle.
robsy
Post Thu Jan 11, 2007 1:20 pm
Mine has the E36 rad with the expoansion tank on the rad - doe the same apply or different due its position??
320Touring
Post Thu Jan 11, 2007 6:53 pm
is it an m20 dude, or is it 4 pot? either way i'm sure it'd work-just raise the very front of the car. but your bleed screw is a lot better to get out
Morat
Post Fri Jan 12, 2007 12:17 pm
Well, I tried disconnecting each HT lead in turn with the engine at idle.. as I took each one off, the revs dropped and the engine readjusted back up to a lumpy idle in a few seconds. Apart from the rear lead (no6?) which seemed to make no difference to the idle. I put it back on and it seemed to be running smoother at idle but once I started off home, the engine was clearly rough and down on power. After about a mile (I couldn't stop due to traffic/narrow roads) it cleared up again and revved just fine with its normal zip.
I reckon there could be something dodgy with no6 HT lead and/or its plug after all. I'll be changing the thermostat on Sunday and I'll try and get a picture up of plug 6, probably compared with one from another cylinder. If its worth it, I could put up a short clip of the idle too.
Also, the rim of the oil filler cap is broken off. Not that flat part, just the "skirt" on one side. It looks like it should make a proper seal, but idle doesn't change when I take it off. So, the cap might be contributing to the problem or it might be fine. Gah, guess I'll have to get one anyway and try it :/
suzie650
Post Fri Jan 12, 2007 2:36 pm
I've seen a C2 touring having a similar problem couple of days ago. Apart that cylinder 6 would only fire 2% of the time, no matter if warm or cold. HT leads were new, and all spark plugs firing well. But plugged on to an engine tuner, you could see No 6 beeing noticably weaker. The new HT lead was naked. The firing outside but not inside was probably due to the higher pressure inside the cylinder. Anyway, HT lead swap, and a roaring 6 again!
Martinaston
Post Fri Jan 12, 2007 3:05 pm
The alternator is not pushing as much current at idle so it highlights the duff lead as it breaks down, If the oil cap is suspect just put your hand over the hole and see if it improves.
There is NO nucleus.
Morat
Post Sun Jan 14, 2007 6:40 pm
Good points Martinaston!
Changed the thermostat today, which took much longer than it should have done because I didn't think to make a note of how the old one was installed and made a best guess which was to put the O ring in first, and then the thermostat. This lead to a steady drip from the thermostat housing when the engine was on. Doh. Took it apart again and put the thermostat in first, with the O ring after that and it made a lot more sense. Anyway, the engine seems to run a little warmer on the gauge, and gets up to the lower white line easily at idle instead of hovering just above the blue.
Also, some cack-handed dickhead (Morat holds up cacky hands) over tightened the bottom 10mm bolt and did something nasty to the thread on the housing so its now a real pain to get the bottom bolt to grip. Luckily the whole affair seems to be water tight, I'll check again with the system really hot and pressurised but I don't really want to drive the car too hard till its fixed.
I managed to get some airlocks in the system but once I'd bled it and got the heater to blow hot air again I had a minor brain wave and remembered that the roads nearby are on a sort of grid, so you can drive uphill 200m, then downhill 200m with 3 nice speed humps per 200m section. This seemed to shake out the last of the airbubbles a treat :) The good news is that when I was doing the radiator flush step from the technical article the water came out clear as...er... water straight away. So it seems I can trust the garage that did it last time to do a decent job.
Lets see how they do with the HT leads. I'm not feeling up to that one myself.
OH, and a 6mm socket is far superior to a 4mm flat head screw driver for undoing hose clips. So remember folks, six better than four :) (except when its only firing on five :x )
I tried sticking my hand over the filler cap hole to see if the idle was improved, but either Martinaston has asbestos hands or I'm more delicate than I thought - it was a bit hot to leave my hand on there for more than about 10s but it did seem to make a marginal improvement if I really jammed it down. So.. a new oil filler cap is going on my list.
thanks for all the help folks!
Morat
Morat
Post Fri Jan 19, 2007 11:25 am
Well the misfire seems to be getting worse - which I guess is what you'd expect if the HT lead IS breaking down. It took a few miles today to bring in all cylinders which felt horrible. I only kept going because it was on its way to the garage so that some proper mechanics can look at it. I hope that running on 5 doesn't do damage - I was gentle with it.
The thermostat seems to have raised the temp on the dial a little bit, and the system is holding coolant so I must have put all the bits back on :)
Wish her luck!
Ant
Retired Team Member
Retired Team Member
Post Fri Jan 19, 2007 11:54 am
CO: 0.87%
CO2: 11.21%
O2 4.91%
Lambda 1.113
CO is too low, the idle mix should be 1.5, that will reduce the HC count bigtime and may help with the missfire symptoms.
M20's like to see aroun 0.95 Lambda @ idle, for some reason the whole shebang is running waaaaaay lean.
Morat
Post Fri Jan 19, 2007 4:06 pm
Lean? this is crazy - the plugs are all sooted up :(
I guess its burning oil instead of fuel, or something.
Thanks for the input Ant. I still hoping to get this to your for MegaSquirt before the next MOT is due!
Morat
320Touring
Post Fri Jan 19, 2007 5:22 pm
Morat wrote:Lean? this is crazy - the plugs are all sooted up :(
Morat
may sound daft, but it IS a 2.5 fpr (fuel Pressure Regulator)
you have on?
2.0 ones a 2.5bar, but yours should have a 3.0.
would that make mixture lean as not pumping enough fuel?
Ant
Retired Team Member
Retired Team Member
Post Fri Jan 19, 2007 5:41 pm
be careful with the FPR,s
"blue" injectors on a 320 = 2.5 bar Reg
"white" -"- = 3.0 Bar Reg
High HC count can indicate many things, based upon the 02 and Lambda I say too lean @ idle, there is not enough fuel to burn correctly and as a result the mix is weak yet you still get unburnt fuel down the 'zaust.
Aren't cars fun :mad: :lol:
320Touring
Post Fri Jan 19, 2007 5:46 pm
Ant wrote:be careful with the FPR,s
see thats what i'm thinking dude- wrong FPR could make it lean. but confused by unburnt fuel in the exhaust and sooty plugs...
Morat, are the plugs "damp" ie is the soot sticky? or are they dry?
Morat
Post Fri Jan 19, 2007 5:47 pm
Yes, fun.
thats the word.
:wall:
320Touring
Post Fri Jan 19, 2007 5:50 pm
Morat wrote:Yes, fun.
thats the word.
:wall:
heh dude! we're trying :D
its still better on 5 cyl than a 4pot fiesta, just remember that :wink:
