Can I fix demisting windscreen, or is it replacement jobbie?
Dr Firefly
- E30 Zone Doctor
Is it true that it's possible to repair broken filaments in a heated rear windscreen? Just as mine only has two working filaments now
JonDubber
There's this stuff you can get from Comma I think, you mask the lines up and paint it on with a little brush. Can't remember the name of it for the life of me, but it is out there...
Chris-W
smithy318i
You can use a product called granville electro connector. Basicly its conductive paint.
stuartgallafant
Dr Firefly
- E30 Zone Doctor
I'm looking into swapping it - but didn't know how much work that would involve. And it'd need to be one that worked... are there many about? Reasonable prices?
To check for a working one, connect 12 volts across it, and probe each line with a volt meter near the middle.
Should be about six volts relative to either end on each one.
Take care not to damage the tracks with the meter probe!
