valve stem seals
jcjdavis1
Post Thu Jan 04, 2007 1:05 pm
Hi How easy are they to change on a 320i.I have the head off, but I cannot find any help in the search section.thanks
Templ8e30
Post Thu Jan 04, 2007 5:06 pm
You need to remove the valves first.
Get a valve spring compressor from the likes of halfrauds to compress the springs, there is a split collar attached to the valve stem that needs to be removed then release the compressor and remove the springs and valve.
The old seals are a pain to remove, a pair of good pliers and a wiggling motion will do it. Don't grab them too hard with the pliers or you'll break the top of the valve guides.
Use a socket to press the new ones in (12mm iirc) being careful not to damage the spring on the seals.
This job is covered in the haynes manual.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Dan318-is
Post Thu Jan 04, 2007 5:11 pm
I used an 11mm socket for the seals; apart from that what he said^
jcjdavis1
Post Thu Jan 04, 2007 5:40 pm
Thanks guys,I took the old head to my work and let the mechanic have a go, a pig of a job to get large cog at the end off.I will print off what you have said and look in the manual.
Chris-W
Post Thu Jan 04, 2007 5:46 pm
If you're having the head faced, you might be as well to get the engineering firm to re-build it for you with the new seals.
jcjdavis1
Post Thu Jan 04, 2007 6:04 pm
Hi Chris should have taken you up on the c/head as this is turning out to be a nightmare.(the road to hell is paved with good intentions).Hopefully no prob with head just getting all the bits done. Jim
