Post
Thu Dec 28, 2006 12:36 pm
Dan,
You should use a smear of silicone sealer where the gasket crosses the joints between the block and the timing/oil seal covers. The rest of the sealing faces should be spotlessly clean and degreased, but no sealer added.
If this is not done, you quite often find oil will weap along these joints. It is standard BMW practice to use silicone on these joints.
Ian.
