Front Fogs
Davenotouring
Post Sat Jan 15, 2005 11:28 pm
Not that I use them much, but my front left fog stopped working. At the same time, the bulb on the dash stopped coming on when you put the front fogs on. Is this coincidence, or does it do this to let you know you have a fog light out!?
Anyway, I bought a new fog light bulb, and fitted it this evening, it still doesn't work? Duff bulb? Or something more dodgy (wiring)? Is the fact that the Dash light stopped working aswell significant?
Thanks for any help!
BMW 328i Cab - Daily Slag
ian332isport
Post Sun Jan 16, 2005 12:45 am
Dave,
It may just be dirty contacts in the fog light switch. Mine did something similar a while back.
I'll take a look on Tuesday :wink:
Ian.
Davenotouring
Post Sun Jan 16, 2005 12:52 am
Excellent, cheers!
Three birds with one stone.
Fogs, Mirror, Switches!
What else!?? :lol: :roll:
Guest
Post Sun Jan 16, 2005 10:23 am
Hi. I had the same problem. Definetley the contacts at the foglight. I can't believe that such a well engineered and put together car suffers from so much corrosion at switch points. I'm slowly going through every contact point and sanding/cleaning!
Ian
johnono
Post Sun Jan 16, 2005 1:42 pm
i got a weird one
front fogs work but no light comes on in the cabin
rear fog doesnt work but light DOES come on in the cabin?
odd
Guest
Post Mon Jan 17, 2005 11:38 am
One of mine stopped working too....what kind of bulbs do the fogs take ?
Davenotouring
Post Mon Jan 17, 2005 12:19 pm
I think they're H7's?
Although they are the small bulbs with the piece of wire attached which has the connector on the end.
PeteE30Tourer
Post Mon Jan 17, 2005 1:18 pm
I have the same problem on my other Touring - left side works fine, but right side doesn't. I've checked the voltage on the connector at the back of the lamp unit and it's dead - nothing there.
If people are suggesting the fog light switch, by which i assume you mean the dash-board switch, how would corrosion on the contacts result in one side working and the other not? Is the switch really a double-pole, with one pole for each side of the car?
Davenotouring
Post Mon Jan 17, 2005 1:23 pm
It's also odd that my dashboard light stopped working at the same time. I've just swapped over the dashboard which had a working fog light bulb, and it doesn't work on this on either.
Simon
Post Mon Jan 17, 2005 3:07 pm
The E30 foglights suffer badly from corrosion around the connectors being exposed where theyre located.
BTW the bulbs are H3's. H7's have the big plastic connectors attatched.
Davenotouring
Post Mon Jan 17, 2005 3:08 pm
That's the one. H3. My dad's old 306 was H7's.
Apologies.
The connectors at the foglight don't look corroded?
Simon
Post Mon Jan 17, 2005 3:12 pm
I'm assuming you haven't checked the switch yet? Or you have and are still having problems?
Davenotouring
Post Mon Jan 17, 2005 3:14 pm
I took the switch out of the dash, which also 'looks' ok, but I wouldn't know for sure.
I'm popping over to Ian332isport's tomorrow to get an illuminated hrw switch sorted, he said he'd take a look. Very kind!
I'll let you know the cause.
Davenotouring
Post Tue Jan 18, 2005 2:04 pm
I popped over to Ian332isports today (thanks again!) who had a look at a couple of problems on my car. The fog one was the most easily solved.
There is a separate fuse for left hand side and right hand side, the passenger side fuse was blown. :roll: For me not checking.
So it is now solved after replacing the rear bulb, which was also gone. (and fuse)
Worth checking incase you didn't know that. :oops:
