black kidney grille?
snoops
- Major Helmet
this might sound stupid but to get a black kidney grille can i just spray it black?or will it not come out good?
Barnz
- Guildford Geezer
Correct me if wrong but if you sand the thing down to get the shine off the chrome, then black paint should stick nicely..... thinking of doing that to mine too, so let me know how you get on bud.
E34 525tds - on the way to replace 325i
E30 / 34 spares
E30 / 34 spares
bigmattpowell
Apparently it works fine but it just may not match the side grilles any more. Get a whole spare set of front grilles and spray it all together. And lots of coats
Barnz
- Guildford Geezer
Good idea mate, thanks.bigmattpowell wrote:Apparently it works fine but it just may not match the side grilles any more. Get a whole spare set of front grilles and spray it all together. And lots of coats
E30 / 34 spares
E30 / 34 spares
Barnz
- Guildford Geezer
Go for it Snoops!
E30 / 34 spares
E30 / 34 spares
Pal318is
Never thought about doing all three bits..that is a stupendous idea
Pal
[img]http://
[img]http://
fuzzy
i rubbed down all 3 bits with fine wet and dry sandpaper to give the paint a good key and sprayed them with black satin paint.that was a couple of months ago and its still in good condition
d6dph
I keyed the kidney, used plastic primer then satin black paint. has been fine for about 8 months of abuse. Plastic primer will flex when stones hit it so shouldn't chip.
I didn't spray the side sections, but I did give them a good coat of Autoglym bumper gel, brilliant stuff for matt black trim, I only used this as that's all I had in the garage at the time.
snoops
- Major Helmet
ye i myt do that but my mate might be sellin the complete grill set with eyebrows, how much do you think i should pay him?
Cotty
- Hartge Crew
Love the black grill
timmyboy
mac325i
timmyboy
GDBN
Easier just to buy a black covers. Then if you don't like it you can take it off.
G
G
325bhpbruiser
just take all 3 off, a good sugarsoap down, rinse, dry, dusting or plastic primer then satin.
only thing to check is no moisture sitting off in the corners of the grill when painting. this way all 3 grills will match mate!
mull3tt
Might be a stuped question but where does the high beam go??timmyboy wrote:good work!!!!
And where do u get these single light grille parts? They make it look mean
noney82
they look so much better with only one ligh per side, can this be done or has it been photoshopped
timmyboy
Pal318is
They look mean for sure...I personally like the yellow lights too..
Good Stuff
Pal
Good Stuff
Pal
Pal
[img]http://
[img]http://
goosiegander
- Zonegoose
Been there and glad, just took the job lot off rubbed it all down and resprayed within about 2 hours...
Teaching myself bodywork and spraying, will try and put some pics up for a laugh on a seperate post, Spraying the lot is the way to go!
E3OSAM
should get a carbon grill they look mint and are slightly more orginal, i did have a painted one but thought carbon was better
OLD SKOOL
noney82
timmyboy how did you make these grills from standard ones i think they look the bees
d6dph
Real carbon or carbon look?E3OSAM wrote:should get a carbon grill they look mint and are slightly more orginal, i did have a painted one but thought carbon was better
