catalistic exhaust
teebaur
hi all i have a 318i catalistic exhaust system and i was wondering if i could fit a non catalistic standerd exhaust system wud it fit? also were wud i plug the lambrough sensor
spence_star
jus get it de cat, get the cat takenn off
Returned after many years out.
Templ8e30
What year is the car ?
If it's on a k-plate or later (1993) it needs a cat exhaust to pass emissions tests.
If it's pre-1993 then you can fit a non-cat exhaust. The Lambda sensor can then be removed from the car, the ECU will operate in open-loop mode the same as all E30's without cats.
Cheers,
Iain T
PS. Your spelling is crap
Cheers,
Iain T
2007 Mazda 6 2.0 estate
jmc330i
August 1992 (from K plate) is the date.Templ8e30 wrote:What year is the car ?
As was said on another thread, in most cases, as long as the car passes the emissions test, it should be ok for the MOT even without the cat.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
