Diff fitting
johnl320
I've swapped quite a few diffs in my time but for some reason the 525e diff I'm putting on my project doesn't seem to want to line up with all four mounting holes on the rear beam. Its only a case of lengthening the two rear holes by about 2mm but has anyone had this before.
cheers in advance
john
cheers in advance
john
jmc330i
Ive had this on both my E30s.
Just trial and error Im afraid. I got the first 2 lined up and the bolts in about half way, then moved the diff around so the other holes were lined up side to side, Then jacked the diff up which moves (twists) the rear beam up and the holes should come into line from front to back if that makes sense.
Not sure if thats the correct way to do it, but its worked for me 3 or 4 times now.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
SPADGE
As James has said they can be a pain.
Don't tighten any of the bolts until they are all located properly as that makes it almost imposible.
320Touring
I thought the e28 diff wasnt a straight swap with the e30 one? IE the coverplate and possibly case are different?
SPADGE
From what i have read the medium case e28 one is the same as the large case e30 one. Its the large case e28 one that doesn't fit320Touring wrote:I thought the e28 diff wasnt a straight swap with the e30 one? IE the coverplate and possibly case are different?
320Touring
is the 525e not fitted with a large case diff then?SPADGE wrote:From what i have read the medium case e28 one is the same as the large case e30 one. Its the large case e28 one that doesn't fit320Touring wrote:I thought the e28 diff wasnt a straight swap with the e30 one? IE the coverplate and possibly case are different?
SPADGE
I doubt it mate320Touring wrote:is the 525e not fitted with a large case diff then?SPADGE wrote:From what i have read the medium case e28 one is the same as the large case e30 one. Its the large case e28 one that doesn't fit320Touring wrote:I thought the e28 diff wasnt a straight swap with the e30 one? IE the coverplate and possibly case are different?
I think just the 3.5's and maybe some 2.8's
johnl320
Cheers for the replies fellas, I've got the front two started and jacked it up wiggled it about but still no joy. Will try again tomorrow. I feel like I've gone ten rounds with Stevetigger
the offending item
bastard thing
john
the offending item
bastard thing
john
- **BANNED**
Johnl320,What ratio is this 525e diff,please?
johnl320
Its a 3.07 mate. Wooohooo no longer a newbie
john
john
320Touring
3.07? what engine and box you running mate?
Jon_Bmw
- Dangerous when thinking
Jon when changing mine for a like to like diff i intially had the same problems, very nearly resorted to re-drilling more mounting holes
but resisted the urge and pushed it harder up with the trolloy jack, the rear beam then moves and it slots in, it then bolted up. I know you already know all this, just stick with it and leave the power tools in the house
So how is the rest of it going, what stage are you now at? I'm feeling a trip up to andover at some point
- **BANNED**
Thanks,I am half looking for a 3.79!!
johnl320
M30 735 lump, e28 m535 flywheel, dogleg box320Touring wrote:3.07? what engine and box you running mate?
johnl320
Alright Jon mate, Its getting trailered up to my work in Warminster mid january where it will finally meet the engine and box. Main things left to do are 1. source rad. 2. fabricate prop 3. fabricate gearbox mount ( ain't payin for an M3 one)Jon_Bmw wrote:Jon when changing mine for a like to like diff i intially had the same problems, very nearly resorted to re-drilling more mounting holes![]()
Welcome to come up for a brew anytime fella
regards
john
320Touring
cool,cool! just asking as I'd been told that the eta (525e) diffs were too long for use with an m20 gearbox...johnl320 wrote:M30 735 lump, e28 m535 flywheel, dogleg box320Touring wrote:3.07? what engine and box you running mate?
I know that the m50 conversions can use a big diff (3.25 or lower) due to the gearboxes having a 5th gear at 1:1 ratio.
johnl320
yeah my dogleg is 1:1 in top320Touring wrote:cool,cool! just asking as I'd been told that the eta (525e) diffs were too long for use with an m20 gearbox...johnl320 wrote:M30 735 lump, e28 m535 flywheel, dogleg box320Touring wrote:3.07? what engine and box you running mate?
regards
john
320Touring
gonna be some fooking machine thenjohnl320 wrote:yeah my dogleg is 1:1 in top320Touring wrote:cool,cool! just asking as I'd been told that the eta (525e) diffs were too long for use with an m20 gearbox...johnl320 wrote: M30 735 lump, e28 m535 flywheel, dogleg box
regards
john
johnl320
Yeah when I eventually get it finished, its been two years to far but it did start out as a 316 carb auto320Touring wrote:gonna be some fooking machine thenjohnl320 wrote:yeah my dogleg is 1:1 in top320Touring wrote: cool,cool! just asking as I'd been told that the eta (525e) diffs were too long for use with an m20 gearbox...
regards
john![]()
320Touring
sleeeper
Jon_Bmw
Excellent, so perhaps i shall pop over easter time, have a wee glance.johnl320 wrote:Alright Jon mate, Its getting trailered up to my work in Warminster mid january where it will finally meet the engine and box. Main things left to do are 1. source rad. 2. fabricate prop 3. fabricate gearbox mount ( ain't payin for an M3 one)Jon_Bmw wrote:Jon when changing mine for a like to like diff i intially had the same problems, very nearly resorted to re-drilling more mounting holes![]()
So how is the rest of it going, what stage are you now at? I'm feeling a trip up to andover at some point![]()
regards
john
Tea, bah.
I'm such a kid!
johnl320
Only have summer fruits in this house if thats alright
Jon_Bmw
It'll sufficejohnl320 wrote:Only have summer fruits in this house if thats alright
johnl320
If I can get her off her fat arse
exup
- Boost Junkie
Hi
When i fitted the 525 eta dif in my 320/ 327 e30 it would fitt as well ,
then i realized if you undo the prop shaft centre bearing and pull it to wards the gearbox it will fall in
, u have to prep load the prop any way , good luck fella
there very tall , gearing ok om a 2.7 poss 2.5 but go good on a 2l IMHO
johnl320
Prop isn't on the car yet mate, but cheers anywayexup wrote:Hi
john
jmc330i
E30 large case = E28 medium case. The rear cover and output flanges need changing for the E30 items and it will fit no problems.SPADGE wrote:From what i have read the medium case e28 one is the same as the large case e30 one. Its the large case e28 one that doesn't fit320Touring wrote:I thought the e28 diff wasnt a straight swap with the e30 one? IE the coverplate and possibly case are different?
Keep at it John, it will fit. The first diff I changed myself was on my touring, I had broke my fingers undoing the prop bolts, so my brother did the heavy work with the diff. He spent about 20mins under the car and then asked me if I was having a laugh.
Another 15-20mins of pissing around with the jack, lowering and raising the diff and we had it bolted upto the beam. Its just one of those things.
Theres probably a 'proper' way of doing it, but now Ive changed diffs a few times that way, I can get it no problems.
James
'91 325i Sport
'91 325i Sport
johnl320
Diff on. Praise the lord only took ten minutes to get the 4 beam bolts in and the rear mount! So what the f*ck was I playing at yesterday?
cheers for the advice fellas
john
john
