Convertible Rear Window Replacement
jazzleeds
Post Sat Dec 16, 2006 8:46 pm
Hi
does anyone know if there is a workshop in yorkshire which can replace the rear plastic window on e30 convrtible. how much is it going to set me back.
thanks
gazza
Post Sat Dec 16, 2006 9:58 pm
if it is a late window then it is zipped in and will take you a couple of hours to do ...if it is a early one then it is stitched and has to be done proffessionaly ...look at ebay for a new window i bought a very good second hand one for £60 and did it myself the old window was out in 10 minutes and the new within 1/2 hour but then it gets fiddly as you have to glue the surround in and let it set ...and the metal clip that secures the zip is a bit hit and miss
lukescott
Post Sat Dec 16, 2006 10:33 pm
My cab is a K reg april 93 model. I cant say I've ever noticed any type of zip mechanism around the inside at all. Are all late ones zipped ? I need to open my garage and have a look.
gazza
Post Sat Dec 16, 2006 11:09 pm
should be zipped look from the inside. or from the outside peel a bit of the hood back if you can see the zip then you have the easy option all later ones are zipped unless you have had it swopped for a second hand one from an older car
orangecurry
Post Sun Dec 17, 2006 8:46 am
jazzleeds wrote:Hi
thanks
is it torn/broken?
If not, and it has just gone opaque (cloudy!), buy a product from Renovo to clear it - it's hard work but it's one of those very rare products in the world which REALLY WORKS :D
http://www.renovointernational.com/prod ... polish.php
jazzleeds
Post Sun Dec 17, 2006 10:01 pm
mine is the 1991 325i convertible. the rear window has been stitched and i have two cracks in it. i need to get it replaced.
