To be honest I've never got on with it in any car I have ever owned and I'm fully aware that for a 90 year old granny it might be great for when they jump on the brakes in a panic but for me I'd rather go for non ABS, especially for occasional track use etc.
I see the master cylinder has two pipes that go into the ABS servo (front and rear brakes), these then distribute to rear/front of the servo. From there the servo splits the front feed to both front calipers individually whilst the back are combined on the same circuit. Hence if one rear wheel locks up then brake force will be omitted from both wheels.
As far as I am aware the ABS servo serves to simply interrupt the brake circuit and doesn't provide any brake boost. Firstly is this correct and secondly will this interfere with brake force distribution if I were to operate the calipers directly from the master cylinder?
All input welcome
