Clutch hyrdaulic pipe broken.
MrDazzle
Post Thu Dec 14, 2006 10:03 pm
Went to replace the master and slave cylinders on my iS today. Turns out the hydraulic pipe from the master to the slave was on it's last legs, now it's sheared clean through.
Anyone know how much it is likely to cost to replace the pipe?
Post Thu Dec 14, 2006 10:11 pm
The metal pipe? (I've never seen a rusty one), or the flexible?
Either is only a few pounds to buy, or less than £1s worth of materials if you make up your own with cupro-nickel pipe. (Easier to get the tight bend out of the master cylinder).
MrDazzle
Post Thu Dec 14, 2006 10:14 pm
Metal pipe....
Nut going onto the master cylinder was all chewed to hell, the pipe had a kink/crack in it about 1cm from the master cylinder. Now it's got a split all the way through it, so it's f*cked. Need the car sharpish, so was wondering how much it'd be for a dealer to fix, bearing in mind I have the master and slave already.
SPADGE
Post Thu Dec 14, 2006 10:19 pm
Sounds like someone in the past has tried to split the flexi and hard line without holding the other to stop it twisting!
SPADGE
Post Thu Dec 14, 2006 10:20 pm
Actually ignore the above i was thinking the crack was at the slave end lol :mad:
Post Thu Dec 14, 2006 10:26 pm
If you're already geared up to change the master and slave, it's only a tiny bit of extra work to change the metal pipe. Just the joint to the flexi to undo.
MrDazzle
Post Fri Dec 15, 2006 7:15 am
CanI buy the pipe already made up?
What about the nut that goes at the master end, is that included?
Post Fri Dec 15, 2006 8:49 am
MrDazzle wrote:CanI buy the pipe already made up?
Yes and yes, but it comes straight.
