diff and gearbox oil
mattcreak
Post Sun Dec 10, 2006 11:50 am
want to change my lsd diff oil and gearbox oil but dont know what to use
please can anone help?
stuartgallafant
Post Sun Dec 10, 2006 11:52 am
LSD oil is Castrol SLX - XJ
Gearbox should be ATF
if the LSD is a medium case, you'll need 1.7 litres, or 1 litre for a small case
i think the g'box is about 2 litres
Templ8e30
Post Sun Dec 10, 2006 4:27 pm
E30 manual boxes run on SAE 80W gear oil unlike E36> which use ATF.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
stuartgallafant
Post Sun Dec 10, 2006 7:06 pm
Templ8e30 wrote:E30 manual boxes run on SAE 80W gear oil unlike E36> which use ATF.
Cheers,
Iain T
iain, i thought they ran on that, but when i put 80 in my iS, it felt really notchy until the car had driven a few miles
bennyboy
Post Sun Dec 10, 2006 10:44 pm
I have just changed my diff after the last one run dry. gonna change the oil next week end but which oil? its a 4,10 non lsd if that means anything. will slick50 gearbox treatment help?
16V IS engine!!!
Post Sun Dec 10, 2006 10:50 pm
Cheers,
Iain T
80 is what is specified for an E30 box, but ATF is a well known (and acceptable) bodge for dealing with boxes that have a stiff gear change when cold.
Templ8e30
Post Sun Dec 10, 2006 11:21 pm
bennyboy wrote:I have just changed my diff after the last one run dry. gonna change the oil next week end but which oil? its a 4,10 non lsd if that means anything. will slick50 gearbox treatment help?
Steer clear of slick50, waste of money.
Non-LSD diff oil is SAE 90w gear oil, get a well known brand.
Cheers,
Iain T
Hyperion
Post Thu Dec 14, 2006 9:34 am
ok, so when do you know when the diff oil needs to be changed?
Templ8e30
Post Thu Dec 14, 2006 10:17 am
It's supposed to be changed at every inspection 2 service iirc.
I change mine every 2 years, probably overkill but cheaper than having the diff rebuilt :eek:
Cheers,
Iain T
