No red light on ma key fob and alarm will not activate also remote locking not working.
I have a spare key fob of the same type but from a different car can this key fob be linked to my alarm.
small single button type from a 93 tourer.
Key fob failure
fuzzy
wouldnt think the other fob would work,did you change the battery on the original fob?
evodan
Yeh man new battery fitted
jcjdavis1
recently got new alarm fitted,since managed to zap fob in the microwave with my chips
ps evodan always liked that video when it was in the charts
evodan
Looking back in some old threads seems I might be able to get the new fob coded to suit my alarm can anyone confirm this, how is this done, dealer only?
If you have an identical fob, and are handy with a soldering iron, then it may be possible.evodan wrote:Looking back in some old threads seems I might be able to get the new fob coded to suit my alarm can anyone confirm this, how is this done, dealer only?
If you look at the print side of the connections to the chip in the fob, you will see how it's coded. Some of the pins will have tracks cut or bridged across with solder.
You have to make the new fob match the old one.
wildeian
A mate of mine took his e36 M3 to the dealer to get an 'extra' key-fob. They downloaded the code from his key and installed it on a new one, but in doing so f!&$£d up his original.
Dealer tried to charge him for the new key without giving him the old one back!! Then tried to charge him twice when it was explained that the intention was to have an 'extra' key.
To cut a long story short, there was some shouting at the dealer
(who still couldn't understand that asking for an extra key means you intend to leave with 2) followed by a phone call to head office.
In the end he left with 2 keys and paid nothing!!!
Could be worth changing the push switch on the original key fob - you could try bridging it with a piece of wire to see if it activates the c/locking...
Red light is usually just a simple circuit from the battery, through the push button, a resistor, the LED and back to the battery, so look very carefully at this area.evodan wrote:No red light on ma key fob and alarm will not activate also remote locking not working.
Try shorting across the little switch contacts if you can't see anything else wrong. If it's the switch, you should be able to find another suitable one from another old remote, or some other scrap electronics. These switches are very common, and there are only two or three types normally.
kam325itouring
sounds like a dry joint in the fob try looking very closely on the solder joints....... if you can see any cracks?? then solder it, that should to the trick!!!!
evodan
Thanks Guys got to the bottom of it by testing the LED circuit as Brianmoooore
sugested. Turned out to be the LED itself
Short term solution, I soldered the 2 LED terminals together and now works
Long term solution get a spare fob from the stealer.
mikey-t
we got a failsafe round these parts!!!!
march109
wuldn't it be cheaper/easier to replace the led!evodan wrote:Thanks Guys got to the bottom of it by testing the LED circuit as Brianmoooore
sugested. Turned out to be the LED itself![]()
Short term solution, I soldered the 2 LED terminals together and now works![]()
