cam timing
daveo
ive just fitted a 288/288 cam can any one explane to me how to setup a adjustable cam pulley thanks dave
reggid
fit it as per normal gear and belt and if needed loosen the nuts and rotate cam hub relative centre portion so that the timing marks on top end and bottom end are both aligned if they are out.
There will be little no adjustment to make unless you have taken alot from the head or block.
Demlotcrew
Its not that simple,
You need to work out the TDC then time in the BTD which would have been on the instructions with your cam.
Andrew
Andrew
reggid
