No spark or fuel...
Cyruz
Post Mon Dec 04, 2006 6:29 pm
After my auto electrician arrived to remove the imboliser I thought that would be the end of my electrical problems... I wish.
Went to crank the engine and it will now turn the starter off the key which is nice but it won't fuel or get spark. This is very weird considering that it was fine before a service and the imboliser packed up. So far I've replaced
ICV, AFM, Blue & Brown Pin Sensors, Timing Belt inc Tensioner, PS belt, Fan belt, Inlet Manifold inc Gaskets, Waterpump and Injectors. This was all done over a peroid of about 3 weeks without the car being actually cranked but with the ignition going on and off for various reasons. The sparky tested the fuel pump connection, ecu and connections, relay, fuses and most other things he could think of but it's still not getting spark or fuel. I was wondering if it's a crank sensor or something of the like because he mentioned that it was the only thing he could think of to try.
Anyone shed any light for me, this is starting to really piss me off and god knows how much the sparky is going to charge...
Chris-W
Post Mon Dec 04, 2006 6:30 pm
Could well be crank sensor...
Cyruz
Post Mon Dec 04, 2006 6:31 pm
Also thought I'd add that if you disconnect the starter the fuel pump runs constantly like it's being bridged, does it work of some sort of system where it earths itself and cuts off on initial ignition of the engine just to fill the rail and injectors.
Cyruz
Post Mon Dec 04, 2006 6:33 pm
Where abouts is this, I'm fine at most DIY jobs but this is a little out of my league so I'm learning fast. It's not the connector on the front of the block that reads from a large pully is it? Also whats the connector that runs to the sump on the right hand side (in drivers seat), just low oil warning sensor?
Nelly
Gumbo
Gumbo
Post Mon Dec 04, 2006 6:41 pm
Buggered ECU it's self? / bad sump to chassis Earth?
Neil.
"I F**KING LOVE YOU GUMBO"
Ant
Retired Team Member
Retired Team Member
Post Mon Dec 04, 2006 6:43 pm
crank sensor is indeed @ the front reading off the trigger wheel, trace the wires back to the plug under the dia socket( m20) and unplug it, using a multimeter measure the resistance accross the two conected pins, you should get 330 ohms
if with the engine cranking the rpms are displayed on the tacho, I doubt the crank sensor is to blame dude
the fuel pump should prime on ign on, then be dormant until the engine is cranked and running.
do you have poer to the ECU itself ? there's an ign on feed and a 12V perm feed, both must be OK for the engine to run.
and just check for any obvious faileure like plug adrift somewhere, auto sparkies are good, but forgetful @ times :lol:
HTH
Nelly
Gumbo
Gumbo
It could also be the 2x uploader relays in the passanger foot well (Orange ones)
Nelly
Gumbo
Gumbo
Post Mon Dec 04, 2006 6:45 pm
LOL Ant - all sounds so familiar LOL.
Cyruz
Post Mon Dec 04, 2006 7:09 pm
Will check all this crap in the morning, I hate my new e30, every time I fix something, something else breaks...
I blame god... well god and karma.
