MTEC2 kit/ Front bumper removal
wildeian
Will the kit that covers the front bumper come off, or do I need to take the bumper off. (and how!!)
wildeian
WillG
for plastic valance there are plastic rivets along bottom going into metal valance then there are 6 or 7 white push in clips along top, so just get the plastic rivets out of bottom then go round to each side and pull outwards and then work your way along the front pulling it off the clips, pretty sure thats how its done but might have missed something, check real oem just inace there maybe a metal clip with thread on that has a platic nut screwed on it on each side aswell
wildeian
Yeah, thats the bit I've got off. Don't want to pull the other bit in the wrong place, incase it breaks!!
Need to get the bumper bit off (with indicators in it)
k
Hi Ian, leather gear going in this weekend,weather permitting.....ref your query, I asked the same question 18th sept, reply from tomson with a diagram was spot on, the plastic type fixings under the lower lip are soon levered out with a small screwdriver and all break. Replacements from Bmw £1 for 8.
The 2 nuts at the end of the spoiler (just in front of wheels) are usually solid and need a dose of release oil and soak etc., I did shear one mine from the captive plastic which is part of bumper, but once off you can clean the area up and Aradite etc the bolt back in position.
You will have it off in no time, the clips between bumper and spoiler are also replacable if any are broken.
Really tidies the front end up once it's all replaced, no gaping gaps.
wildeian
Cheers Malcolm, thats a job for tomorrow afternoon!!
wildeian
I still need to get the bumper section off, I'm guessing it's undo the 2 hex-capped bolts under the bumper, and the whole lot comes away?
Anyone??
Anyone??
ROC
Yep, as you say take the two bolts out. Then pull the bumper forward, unplug the indicators, job done.
wildeian
Bugger!! one is rounded!!
march109
Any one know part numbers for them? my bmw parts desk doesnt have a clue and real oem tells me theres no such part!k wrote:Hi Ian, leather gear going in this weekend,weather permitting.....ref your query, I asked the same question 18th sept, reply from tomson with a diagram was spot on, the plastic type fixings under the lower lip are soon levered out with a small screwdriver and all break. Replacements from Bmw £1 for 8.
k
I posted a query 18th sept ref these bits and tomson replied next day with a diagram from the BMW dealer which clearly showed the plastic bits that hold the bottom edge of the spoiler in position. The local agent soon found them and did actually have them in stock.
Have a look at the thead.
If you don't have any joy send a pm and I'll pop in and get the number.
gcorky
- Boost Junkie
