low idle
rj
Post Sun Dec 03, 2006 2:14 am
Hi guys
I have a 1990 320iA, with 156000 miles on the clock.
The engine responds well and has no major glitches apart from a low idle, around 680-700 and there is a slight "stumble" which is almost like a very slight miss.
I just completed an Inspection I and additonally replaced the d. cap & rotor as there was wear and towers 4 & 6 had slight cracks.
The response otherwise is very smooth and whilst the plugs are slightly light the mixture seems fine.
Any suggestions?
pnd
Post Sun Dec 03, 2006 10:55 am
dont know whats causing this but fit a chip from the zone shop which will raise your idle slightly and very likely solve the problem.
