I have a foreign body in my 320 touring! UPDATE WITH PICS!
SPADGE
Post Wed Nov 29, 2006 11:13 pm
I was doing a few routine maintenance jobs on my 320 touring today when i spotted a pipe which doesn't connect to anything and i havn't seen one before like it! It is on the passenger side under the bonnet and is laying on the chasis rail finishing in line with the abs box. It has a banjo type end affixed to a thick rubber pipe very similar to a power steering pipe but then it goes intowhat looks like a metal brake line and back under the car to the rear and finishes top right under the passenger wheel arch where it has the same rubber pipe and banjo connector and it is tied up and connects to nothing :? :eek:
Anyone shed any light on it as i can't :?
kam-325i
Post Wed Nov 29, 2006 11:17 pm
remains of a LPG conversion ?????
SPADGE
Post Wed Nov 29, 2006 11:24 pm
kam-325i wrote:remains of a LPG conversion ?????
Crossed my mind mate!
I'll have a good look in the spare wheel well etc...tomorrow to see if i can find any evidence of a tank having been in there.
Post Wed Nov 29, 2006 11:32 pm
Think you'll find that's the vent line from the fuel tank! Free end should be pushed into one of the holes in the reinforcing bracket for the front left suspension turret. Goes to a carbon canister if you have an emissions equipped car, then to a solenoid valve, (spare connector off the AFM loom), and then to the inlet manifold. (spare pipe connected to nothing at one end hanging off the inlet manifold on 4 pots).
SPADGE
Post Wed Nov 29, 2006 11:35 pm
Brianmoooore wrote:Think you'll find that's the vent line from the fuel tank! Free end should be pushed into one of the holes in the reinforcing bracket for the front left suspension turret. Goes to a carbon canister if you have an emissions equipped car, then to a solenoid valve, (spare connector off the AFM loom), and then to the inlet manifold. (spare pipe connected to nothing at one end hanging off the inlet manifold on 4 pots).
Brian i know what you mean but its nothing like that. I had one of those on the L plater that i have just converted and it was just like a 3rd fule pipe running into the carbon cannister etc..This has the big rubber pipe at each end with the banjo connectors as i said just like the ones going to the power steering pump!
SPADGE
Post Wed Nov 29, 2006 11:36 pm
btw this is a 1990/H 320i
SPADGE
Post Wed Nov 29, 2006 11:38 pm
And whilst we are on that subject Brian what should i have done with this 3rd line on my converted touring as i have done away with the cannister? I have just blocked it off for now is that ok or should it just vent to atmosphere??
Post Wed Nov 29, 2006 11:42 pm
In that case I've never seen anything like it either.
Doesn't really sound like a LPG pipe. That is normally black plastic covered 6mm steel pipe, and shouldn't have any rubber bits.
Post Wed Nov 29, 2006 11:44 pm
SPADGE wrote:And whilst we are on that subject Brian what should i have done with this 3rd line on my converted touring as i have done away with the cannister? I have just blocked it off for now is that ok or should it just vent to atmosphere??
Don't block it off! You'll suck the fuel tank flat! Tuck the end of the rubber hose into the strut reinforcement.
SPADGE
Post Wed Nov 29, 2006 11:45 pm
I'll have a better look tomorrow and maybe take a pic or two as they may help identify it.
Cheers Spadge..
SPADGE
Post Wed Nov 29, 2006 11:46 pm
Ok will do don't panic Mr Mannering :D
SPADGE
Post Thu Nov 30, 2006 11:56 am
Thought i would check this out today and see where the pipes go!
Opened the boot and removed the spare to find this
Then removed that to find these :eek:
Its got BMW on the white lid thing so its obviously factory but what is it??? Suspension related????
oze30
Post Thu Nov 30, 2006 12:00 pm
I think its for rear shocks when towing... self adjusting dampers??
ETK?
eko
Old timer
Post Thu Nov 30, 2006 12:03 pm
Similar set up to an E34 tourer,weight adjustable steering?
oze30
Post Thu Nov 30, 2006 12:04 pm
oze30
Post Thu Nov 30, 2006 12:07 pm
wonder how much it was worth
SPADGE
Post Thu Nov 30, 2006 12:39 pm
Cheers guys thats that riddle solved :D
Skip
Post Thu Nov 30, 2006 12:45 pm
Add that to the "rare parts" thread Jules! :wink:
ex-325i Touring
TouringMatt
Post Thu Nov 30, 2006 6:51 pm
Quality find 8)
SPADGE
Post Thu Nov 30, 2006 7:56 pm
Skip - somebody already has :wink:
Matt - Yeah great but no use to me or the car but for novelty value its priceless :D
buster
Post Fri Dec 01, 2006 2:22 pm
thats well bizzare.I've never seen that before.I bet many werent fitted with that 8O
316vinni
Post Fri Dec 01, 2006 2:44 pm
Ive never seen that before :mad:
stuartgallafant
Post Fri Dec 01, 2006 4:22 pm
ive NEVER seen that on an E30!!!
Trent
Post Mon Dec 04, 2006 12:50 am
Funnily enuff neither had I untill i bought my touring off ebay last month. but sure enuff thats what it is. The fluid is different i believe and it sits in a pot where the pas normally is. (does both?)
but since most people here are suprised to see t does any body know of its advantages? handling wise? the guy i bought my car off said it was the best handling car he'd driven but then the previous 325 i had was(to me), lowered mtech + 40 i think??? this one i havent driven yet as the head gasket has gone and i'm slowley repairing it.
Martinaston
Post Mon Dec 04, 2006 6:03 am
Spadge, get a pic of the bit under the car if you can. Is it linked to the roll bar ?
You could modify it so it reverses body roll when you throw it into a corner :mad:
There is NO nucleus.
kombikat
Post Tue Dec 05, 2006 2:09 pm
My lhd tourer is fitted with self-levelling so it keeps it end up when heavily laden and not many can say that!
It was extra and cost c£1000 when new.
It involves a different pas pump and uses Pentosin oil (either green or red).
Gordon
