Hello people, i'm getting myself an earlier 2.5 engine (from Mtec I) for my Mtec II Sport that requires a new lump.
Can I just ask what complications there might be with installing the lump? For example, will it be a straight out & in jobby or will there need to be any customising? Assuming that all the bits are there etc?
Also, considering whether I can put my 288/288 cam in with high performance valve springs but need to get the tolerances checked by a specialist as had a problem with my engine, hence the replacement.
Would anyone recommend swapping the valves as well as my old head was rebuilt 1k miles ago. Not swapping the heads over, my mechanic says it's too much hassle-so fair play!
What are the benefits from the Mtec I lumps? A few people have mentioned that they are livlier to drive?
Any help will be much appreciated.....
Regards, BJ.
**Mtec I lump in Mtec II engine bay**
BIGJO
Dan318-is
The early lump will require a later front pulley, later crank shaft position sensor, and later water pump I THINK, i cant remeber exactly although its easily done mate. ask ant/brianmooore resident hal-e30 bots.
BIGJO
I have all the later bits in my Mtec II engine bay. The only problem is swapping a few of the parts over, correct? Anyone know what the bits are exactly?
I will ask Ant & Brianmoore for help as well...
Regards, BJ.
Regards, BJ.
Ant
- Retired Team Member
Dan is spot on, trigger wheel and front sensor, waterpump and the HT leads , other than that drop her in for the full fat 9.75:1 Compression M20
night and day livlier, will seem less torquey though ( its not)
Email FTW
Dan318-is
iirc, the only problem you will occur upon is torqueing the front pulley; 410n/m i believe is the torque; air gun territory im afraid!!BIGJO wrote:I have all the later bits in my Mtec II engine bay. The only problem is swapping a few of the parts over, correct? Anyone know what the bits are exactly?
Regards, BJ.
Ant
Not true Dan, the pulleys are held on with 13mm headed M8 bolts, the nose bolt(24mm) can stay put - result
Email FTW
BIGJO
Thanks Ant & Dan. The information provided is much appreciated
Regards, BJ.
Regards, BJ.
