M42 fuel pipes?
bennyboy
Post Thu Nov 23, 2006 7:15 pm
im using loads of fuel at the mo with this new engine. i got 100 miles out of £20. However, when i stop, it stinks of petrol. are the pipes round the engine prone to failing?
16V IS engine!!!
Bob_S
Post Thu Nov 23, 2006 7:24 pm
could be the o-rings around the injectors, easy to replace :)
Bollocks to this 24v scrap!
stuartgallafant
Post Thu Nov 23, 2006 8:00 pm
the pipes under the inlet manifold are prone to going
Dan318-is
Post Thu Nov 23, 2006 8:06 pm
The pipes in the engine bay themselves are fine; its a small 2 inch rubber connecting pipe that leeds from the fuel feed to the injector rail itself; the return one hardly ever perishes in my experience.
Number 15 is the leaking candidate!
E30Mark
I'm with Stuart on this, the rubber pipes under the inlet manifold always fail!
You have to remove the inlet manifold to change them, not a hard job to do....
/off topic/
Stuart, have you got those wing prices.....
PM for details
stuartgallafant
Post Fri Nov 24, 2006 3:10 pm
mark, i do, but im away on a training course, with no access to my toolbox, which is at worked, all locked!
however, i may be popping tomorrow (sat) to get some tools, so i'll grab them then
sorry mark, i just been so busy, but never fear mate!!
Post Fri Nov 24, 2006 9:02 pm
ANY fifteen year old high pressure rubber fuel pipe is due for replacement.
stuartgallafant
Post Sat Nov 25, 2006 12:05 pm
Brianmoooore wrote:ANY fifteen year old high pressure rubber fuel pipe is due for replacement.
i'll second that!!
