Does anyone know what diameter brake pipes BMW use. Is it 3/16, or do they use a metric size.
Jason
Brake pipe help
Ant
- Retired Team Member
German cars are all metric M8, 100% on that
Email FTW
dogsdanglies
Ok, Thanks ant. Does anybody know the exact sizing, would like to buy a length tomorrow.
It's the same pipe, metric or imperial, 3/16" or 3.67mm IIRC.
It's just the ends that are different, and only slightly at that. Thread pitch is very similar, and the metric fitting diameter is slightly smaller than the imperial.
Bought 20 metric male ends yesterday, confirming twice at the factors that they were metric. Made the first pipe up and screwed it into the rear axle tee piece - immediately stripped the thread - muppet had given me imperial.
dogsdanglies
Ok thanks mate, just need to find a motor factors open tommorow that sell the stuff
320Touring
saves me askin....
cheers lads!
cheers lads!
calder
the nut size on on the fittings is also imperial - 7/16" IIRC.
it took me a while to work out why my metric spanners weren't working so well
