Rev counter broken
pobby
Post Mon Nov 20, 2006 2:51 pm
Hi there i have a 1989 316i (wish it was a 325is but i am only 18) and the rev counter has stopped working. Any ideas ?
marty1979
Post Mon Nov 20, 2006 3:32 pm
It could be a fuse, I somehow managed to blow the fuse for the rev counter when I was fitting my stereo. Can't remember what number it was but if it is blown you'll find it with the rest in the fuse box under the bonnet. Hope this helps :)
smithy318i
Post Mon Nov 20, 2006 3:33 pm
could be one of a few faults.
could be dead SI board batteries.
could be a loose connection inside the cluster.
could be just a dead rev counter.
or could be the wrong code plug inserted into the cluster.
how long has it been broken?
does it sometimes work if you hit it?
do any of the other instruments not work? (eg MPG swingometer thingy)
(or it could just be a fuse)
timmyboy
Post Mon Nov 20, 2006 5:12 pm
some numpty fitted 5 watt bulbs into my cluster instead of 3 watt, they melted all the contacts for the rev counter, could be that???
(00=[ll]=00)
Image<embed></embed>
pobby
Post Tue Nov 21, 2006 4:50 pm
its only just broken. Not with the car at the mo but will find out if mpg gauge is workin or not. What will it mean if it is working or not. Will also look at the fuses. Thanks for the help so far.
318i1989
Post Wed Nov 22, 2006 11:07 pm
hi i had a problem with my instrument cluster. the rev counter stopped working which i ignored. Then the fuel economy meter stopped working. It was likely to have been a faulty SI board (the battery on the back of can go flat too if theyre too old.
I bought a new replacement cluster from a BMW salvager which cost 30 quid but solved the problem. Might be worth thinking about if you don't have any luck fixing your instrument cluster
ricey46
Post Thu Nov 23, 2006 10:21 am
I had this problem but sorted it by replacing the rev counter, and screwed in another one from a younger(G-plate) 325! Works perfect now!! :D
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
Barnz
Guildford Geezer
Post Thu Nov 23, 2006 10:29 am
Have this problem right now - temp gauge not working either - just bought an SI board off Fuzzy and hoping that's gonna fix my woes....... then I can get "OKK" back on the road! :cool:
E34 525tds - on the way to replace 325i
E30 / 34 spares
ricey46
Post Thu Nov 23, 2006 10:33 am
My Temp guage use to fluctuate up and down when accelerating but has stopped that now!!
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
marty1979
Post Thu Nov 23, 2006 1:10 pm
I had the same problem with my temp gauge, I took the cluster out and found that the nut holding the gauge onto the board was mega loose, screwed it tight and it's spot on now. The nut holding the fuel gauge on was completely missing though 8O
charlie316
Post Thu Nov 23, 2006 2:31 pm
Ive had this problem a couple of times, i just had to replace fuse 21 i think, also i removed this fuse last week and it stopped the interior lights and the cd working, so check these are working.
ric325i
Post Thu Nov 23, 2006 3:05 pm
no rev counter would be a nightmare!!! especially for me cause my speedo dont work!
could these solutions for the rev counter also have the same affect for the speedo?(not stealing the tread, just developing :D ).
i have changed my speedo sensor on the dif but only works occasionally and if you punch the dash some times it works? :mad:
does the rev counter connect to the dif or gear box?
oh so many questions.
