Mounting drivers lower trim to steering column
FlashBastd
Post Thu Nov 16, 2006 1:31 pm
The drivers side lower trim on my car is mounted into two guides against the bulkhead, and held on with 3 plastic screws at the top, but still seems to sag a little about half way along. There is a slot in the trim panel to fix it to the underside of the steering column, but when I look on RealOEM there is nothing shown for my chassis No.
Is it as simple as a screw and washer? Or is it something cleverer?
Thanks!
1993 E30 318i Lux Auto Touring - SOLD
2001 Ford Mondeo 2.5 Zetec-S 5dr - SOLD
2004 Lexus IS300 Limited Edition Auto - SOLD
2005 Honda CR-V 2.0i Executive Auto
2001 Ford Puma 1.7i Black
dazleeds
old skool raver
old skool raver
Post Thu Nov 16, 2006 1:33 pm
there should be a plastic twist type screw in the slot you mentioned goes thru slot and into steering
column then push hard and twist to lock
no more sag :D
www.oldskoolfantasy.co.uk
FlashBastd
Post Thu Nov 16, 2006 1:34 pm
Any idea of the part no? Or does anyone have one knocking about?
Simon
Post Thu Nov 16, 2006 7:24 pm
Pinch one from the plastic cowl that covers the back of the headlights.
FlashBastd
Post Thu Nov 16, 2006 8:56 pm
Is that was is supposed to be there?
eko
Old timer
Post Thu Nov 16, 2006 9:01 pm
FlashBastd wrote:Is that was is supposed to be there?
Its what ive got in mine winkeye
jon_pure_british
Post Thu Nov 16, 2006 9:06 pm
i hate my one, it falls down most of the time, also prevented me from lifting my accelerator pedal once 8O
Clacton-On-Sea
Essex
Post Thu Nov 16, 2006 9:47 pm
I've seen the slot in the trim panel, and I've seen the matching slot in the underside of the column, but I've never seen any clip fixed here. Trim should be held up at the front by a plastic bracket on the bottom of the steering column and a three pronged spring clip above the accelerator pedal. Also hooks over the heater outlet a little.
Chris-W
Post Fri Nov 17, 2006 8:50 am
I've not had one come to me with a fastener in that spot either, but the little black twist fastener does do the job perfectly.
d6dph
Post Fri Nov 17, 2006 8:54 am
Mine came with the twist fastener, not sure if it was originally there but works a treat.
Rosc0PColtrane
Post Fri Nov 17, 2006 9:48 am
Mine stopped my foot too. Eventually got knackered. So I roke the bottom part of it off and haven't replaced it. It's fine now!!
orangecurry
Post Fri Nov 17, 2006 10:28 am
the things I do...
top one is from the plastic headlight cowl
centre is the 'normal' trim fixing
bottom is the one you don't have, and that Brian has never seen winkeye
....and no this isn't a spare - I've just dismantled my car for the photo :mad:
jcjdavis1
Post Fri Nov 17, 2006 5:35 pm
Hi they are cheap at the stealers as I had to replace mine.
dazleeds
old skool raver
old skool raver
Post Fri Nov 17, 2006 5:37 pm
yep first one in orangecurry,s pic is what i always use :D
Morat
Yeah, I need a set too :/
bmwe30mtech
Post Fri Nov 17, 2006 5:43 pm
I use a small bolt with a nut and washer on it. Tidy and strong.
