Rattling load cover on Touring
FlashBastd
Anything I can do to reduce the rattling?
1993 E30 318i Lux Auto Touring - SOLD
2001 Ford Mondeo 2.5 Zetec-S 5dr - SOLD
2004 Lexus IS300 Limited Edition Auto - SOLD
2005 Honda CR-V 2.0i Executive Auto
2001 Ford Puma 1.7i Black
dazleeds
- old skool raver
they usualy sit in tight on the brackets
are the screws lose that hold em on??
is thew cover clipped in properly??
cant think of anything else that would make that rattle
www.oldskoolfantasy.co.uk
FlashBastd
Thanks for that, I will investigate further.
chippenham_touring
mine rattles too, i might try putting silicon grease in the clips
Jesus325iTouring
- Frog freak !
Hello local dude,whats your Touring look like? I live 2 miles outside Chipp' probably seen you about.chippenham_touring wrote:mine rattles too, i might try putting silicon grease in the clips
FlashBastd
I don't think grease would help. I think the springs need to be tighter
The load cover should be under considerable spring pressure when it's in place and shouldn't be able to rattle. Or do you mean the cassette is rattling in its holders when the cover is retracted into the cassette?
Royalratch
These things always rattle. On my last 2 Tourings it was simply the rolled up cover not being a tight fit in the brackets. Never been in an E30 Touring that didn't rattle like mad in the back - been in a few...
FlashBastd
I think it is rattling where it mounts into the sprung brackets at either side. If I grab it, there is plenty of fore and aft movement, though the actual brackets are well fixed.
toby
Sure it isn't the seats? If you lower the seats are the little brass poles that the seats clip onto loose?
Like Brian says it shouldn't actually be able to rattle at that point...
FlashBastd
Well I drove home with the shelf on the back seat, and no rattles.
I've never heard one rattle on a touring! There are springs in the mounting brackets, which I presume stop them rattling. Whether there's anything adjustable here I don't know, as I've never had a rattle.
Nothing in a BMW should rattle, full stop! If it does, something's not been adjusted properly.
Jesus325iTouring
- Frog freak !
The only thing that rattles in my Touring is my missus,at me,if i'm in a "rush"!
Gortour
My Touring doesn't rattle. Maybe the brackets that hold the cassette are broken, one of mine is, on the top bit that stops the cover lifting out of the bracket. Or the springs have sprung. If shaking just the cassette doesn't cause a rattle, I can only suggest put new clips on. Especially if the cassette rattles in the brackets.
Royalratch
I've had 3 Tourings that rattle. My brothers rattle. All from the back. The cars are old and it happens. Let's not get it twisted, I love the brand but if shit rattles hey - what can I say?
My CoupÃ…a and my brothers Saloon are solid as granite.
! have six tourings, and not one of them rattles! BMW do not do old cars. Everything should fit and work (except the headlamp levelers) just as it did when it left the factory.
Any rattles are down to poor/incompetent maintenance.
ad318i
sounds like something as broken...
...like one of the plastic connectors and cant get free.. take the cover out to get a better look
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
Morat
Sucking eggs, but are you sure that the load cover is properly snapped into place? It can take some effort.. You need to twist it to lock it in. The first few times I tried it I didn't have it locked in, and I only locked it properly when I got pi%%ed off at it
(ignore me if you've tried this).
FlashBastd
It is definately fixed in properly.
