Fuel Pump!
marty1979
Evening all, hope someone can help me with this one. Now I know my fuel pump needs replacing as it's mega noisy, but unlike other cars I've had, when I turn the ignition on I don't hear anything from the pump, like it priming itself. Why is this? Thanks in advance
garyp_E30_325i
You should hear the pump priming, if it's not priming it's probably gone (or the fuse / relay has gone) but then the car wouldn't start. What model you got? If it's got an external pump under the car maybe you won't hear it. I've got the in-tank pump and so long as you pause the ignition key you can hear it prime.
'89 325i - was an SE but not anymore, was bronze-beige metallic (yeuch!) but now techno-violet (thankfully)
'89 Toyota Corolla GTi-16 - track, hillclimb & sprint car (yeeha!)
'08 Buell XB12Ss - American engineering at it's 'best'... good fun though
marty1979
Hi thanks for the quick reply. It's a 1988 320i, as you say if it was a fuse or relay problem it wouldn't start, but it starts and runs ok with only slight hesitation and power loss, to be expected from a dodgy pump.
garyp_E30_325i
A '88 320i should have an in tank pump (I think?), so if everything is off and you turn the key to the on position and leave it you should hear the pump prime from just behind the drivers seat. You need to take the rear seat out to get to the inspection panel above the tank, there's a tech article on how to change a fuel pump posted by 320Touring:
http://www.e30zone.net/modules.php?name ... chfuel.htm
Chris-W
marty1979
Thanks for your help guys, this site is awesome
Could an early '88 320 have the two pump set up?
If it has, a noisy external pump is normally the result of a failed transfer pump in the tank.
marty1979
That's interesting, what would the symptoms of a failed transfer pump be, other than a noisy fuel pump?
Chris-W
Is there a pump in front of the left hand rear wheel?
AFAIK, failed transfer pump doesn't cause any real symptoms, other than the noise and eventual early demise of the main pump.
marty1979
Ok, I pulled the pump out and stared at it for a bit
, put it back in and it's not making noise anymore. Still doesn't prime before ignition though. Any ideas?
cyborgguy
My 88 320i is the same it doesn't prime with the ignition switched to on before starting.
It is also hard to start sometimes. (I have already replaced distributor cap and rotorarm.)
If I short out the fuel pump relay I can hear the fuel pump so I know it's definately not priming before startup as I can't hear anything.
Any idea's as to why it wouldn't prime?
