Removal of rear bumper
e30bemer
Nutters
Nutters
Post Thu Mar 24, 2005 10:39 pm
I know it sounds stupid but, 2 morrow i will be fitting a AC schnitzer rear apron, and it screws just under the bumper!
just wanna know how to remove the rear bumper, and how easy it is!
I can assume that its a piece of piss, but dont wanna do it, get the hump, and start throwing things!!!
any help please!!!!
thanks
e30 bemer
Post Thu Mar 24, 2005 10:49 pm
Assuming your's is post facelift car, then unscrew two large bolts under the bumper going straight upwards,( either female hex or torx headed ), and pull the bumper straight backwards. (side pieces of bumper slide into two guides just behind the wheelarches).
e30bemer
Nutters
Nutters
Post Fri Mar 25, 2005 12:04 am
mine is the post face lifted model! will look 2 morrow
mant thanks
mate
e30 bemer
Treeman612
Post Fri Mar 25, 2005 1:22 am
hi, one word of advice, having done it myself - if you have access to another pair of hands, i.e. a mate (?) it will make the swop a lot easier - you have to hold the bumper in position horizontally, to get the holes for the 2 big torx bolts 2 line up, plus you have to feed the front of the bumper 'wings' in to slots on a bit of metal bolted to the rear wings (both sides at the same time!!). It's a b**ger on yer own!
HTH
Jon
