Well, I have a little problem, think I may know the answer, but you very clever encyclopaedic oracle like bods may throw me a bone here.
The past few mornings, on my drive to work, as I accelerate up to Naitonal Sped limit, I change gear, into 4th or 5th, the car splutters, and if I keep my toe down, will back-fire, sending a plume of dusty smoke over any following vehicle.
I can avoid the back-fire by dipping the clutch and coaxing the revs back up and raising it again.
My understanding of back-fire is when unburned fuel is ignited in th ehot exhaust?
If so, what is causing this. It's not the best starter in the morning, inspite of recently being serviced. More so in the wet or cold weather. The Ht leads seemed to be ok. I'm thinking it's a poor spark and replacing the HT leads may be the answer.
However, what with the cooler weather, I'm thinking it also be, or compounded by, over fueling?
I had a E plate 520i before and that over fuelled, inspite of temp sensors being replaced.
Oh my car is a 320i Cab on a H plate. Any ideas would be gratefully received, oh mighty wise ones!!
