Hi
Last weekend I tried to fit a set of braided brake hoses, did OK but only got 4 of the 6 on as two of the four rear ones are well hidden under the rear crossmember.
Does anyone have any tips for doing this or do I need some sort of special tool??
Rob.
Rear Brake Lines
old_skool
No special tools, 11mm brake pipe spanner, a 14mm spanner for the hoses and patience. It isn't the easiest of jobs but it is possible.
tobias
as above done mine on sunday. may wanna removve heat sheild from above exhaust
LeeInMontreal
The trick is that because you will not use the old rubber lines, you can cut them as close to the steel fittings as possible. That will allow you to use a deep socket and an extension. Use your ratchet wrench to undo it. Much easier. 10 minutes per side.
tobias
wish i asked same q on sat
k130
Thanks all for that.
I think I may have one more go at it then get my local garage to do it if I fail...
tobias
think positive alittle patience an you will be fine. goodluck
k130
cheers, will let you all know how it turns out...
