Guys,
Gonna have a 2.7 engine rebuilt before it goes in the car and want some more info on lightening/balancing.
Did a search and found this post clicky which helped a bit, but could use more info!!
Don't want this to turn into a should/shouldn't debate!!
I know basics, but not details.
Car is going to be mainly for fast road use and occasional track use.
So what exactly do i get balanced and lightened??
Can anyone recommend somewhere to do this job??
Any ideas on what it should cost me??
Do i need to give them specs or do they work it all out??
Cheers.
Lightening & Balancing.........
miniblob
327 Touring with bass!!!
tomson
Your 1st 2 questions are answered in the thread you allready found dude,
the 3rd is a matter of opinion and the last 2 the yellow pages will provide
reggid
if you use pistons/rods that didn't come from the factory with the crank you are using it will help to make it rev smoother and somewhat minimise out of balance forces. All they do is grind small amounts here and there from the crank counterweights and/or rods/pistons and what not.
Also get your crank pulley/harmonic balancer and front pulley balanced as complete set. Do the same with the clutch and flywheel assembly.
Turbo-Brown
- Boost Junkie
By all accounts, VibrationFree (think it's vibrationfree.co.uk) are supposed to be very good.
No idea how much they'd charge, but I gather that you supply them with your engine in bits and they do the rest.
Guess though that if it goes to them in bits it's gonna cost a LOT of money!
beem
I can recomend wilcox engines, http://www.wilcoxengines.demon.co.uk/ they will work on any engine be it 4cyl or 6cyl. just had my crank,flywheel,conrods balanced and lightened on my toyota twin cam engine for my rally car. crank was Ԛ£45 balanced rods were the same.John Wilcox is a tried and tested builder on rally scene.
