My 325i SE has a replacement engine, so putting the engine number on the plate on the front of the engine bay into the ETK comes up with a slightly different variant of the engine that is in there now.
Is there a number stamped on the actual engine that I can use instead?
There is a number (1176565) on the engine mounting bracket at the base of the dipstick, but that comes up with 318iM10 - obviously no good...
I haven't been able to locate any other numbers on the engine itself yet.
Engine number
Templ8e30
The engine number is stamped onto a flat portion of the engine block near the sump on the passengers side above the oil level sensor.
Pictured here marked yellow
Can be hard to read because of it's position.
Hope this helps.
Cheers,
Iain T
Hope this helps.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
