juddery wipers
markyboy
Steviec
What setting does this happen on?
If its intermittent, then the motor just needs taken out and the disc section cleaning (see articles section above).
<a><IMG></a>
SGP
clean the screen with a strong solution of clearalex or similar and clean the wiper blades too.If that doesn't work change the blades.Traffic film is the culprit.
If it ain't broke..
Fix it till it is
Fix it till it is
Steviec
I get the same but I think mines just down to crap wipers! Ive never been happy with them.
Whats Clearalex and where do I get it? Is it like Rain X?
<a><IMG></a>
SGP
Clearalex is just a granular cleaner for the wash bottle,usually found at filling stations but any good glass cleaner should do.I reccomend changing the wipers every 6 months,often neglected,they also mark the windscreen eventually with grit building up on the rubber.
If it ain't broke..
Fix it till it is
Fix it till it is
Steviec
I use Meguires glass cleaner but I still get the judder, ive only had my wipers about a month and they will be going in the bin very soon and ill pay the extra for some decent ones.
<a><IMG></a>
wildeian
Wipers have been crap on both my e30's!!
Anyone ever upgraded the motor to one that isn't so high maintenance? (possibly off a different model??)
SGP
priracing.co.uk have some pretty cool looking silicon wipers I,ll try them next time.but seriously though traffic film and even certain waxes cause this problem the screen needs to be really clean, alcohol such as head cleaning fluid for tape decks is another good grease buster.Some forecourt washes even supply an alcohol wipe thingy to get the wax off the screen after the wash.That juddery noise is a real pain in the a$!se!.
If it ain't broke..
Fix it till it is
Fix it till it is
gooner1
- Out humping Reindeer
Just put half a bottle of vinegar in a bucket of warm water then dry your windows with old newspaper.
domross
Yup and then wipe the wiper blades down with neat vinegar on a cloth!!
If this juddering is on one of the continuous wipe settings, then the problem is a worn output shaft bearing on the motor.
The conversion from a left hand drive design to right hand drive leaves the motor spindle exposed to the elements, and it wears badly.
There are motors from other makes of car that can be used, and since they are usually better protected, and the car they are in reaches the scrapyard in half the mileage of a BMW, they are usually OK.
Because of the position of the wiring connectors on these motors, the bulkhead under the motor may need a little "adjustment" with a hammer.
ant2
what car does the other motor come out of ? mine judders on the constant setting and often stops all together
Can't remember! I collected several various likely looking candidates from a scrapyard, and found a couple that would fit.
Think one might have been from an Audi, but I'm not sure.
Have a good look at an E30 motor, than scour a scrapyard or two.
The fitting problem was that most motors have a socket mounted on the motor instead of the flying lead with a socket on the end like the E30 has. It's the socket that fouls the bulkhead.
Couple of extra washers under the motor helps, and you will need the plug off the donor car and the lead off the E30 motor to make an adaptor lead.
gareth
i'v noticed that the wipers on all of the E30's i've had feel like those on a real classic car!
are the E30 wiper motors slower than most others? the E34 we have, and several cheap peugeots we've had all have much faster and stronger wipers than my E30, which is cary as the E30 is by far the fastest car i've had since a 180bhp mk2 escort (which had terrifying wipers!!!!!)
