m50 timing?
Hadez
Post Thu Oct 19, 2006 4:50 pm
M50 25i valve timing, basic crank and cam shaft setup if any body knows it?
stonesie
Post Thu Oct 19, 2006 11:14 pm
its a chain and from memory there are clear(ish) timing marks on the sprockets :wink:
Hadez
Post Thu Oct 19, 2006 11:45 pm
yes it's a timing chain, on the cam's are 2 arrows opposite each other and on the crankshaft is 6 holes altho 5 are drilled through and the 6th ond is is just a indent, like half drilled.
i gather that the arrows on the cam's line up with each other and are inline with the head but can't find any thing on the block that the crank should line up to (a crappy pic to help explain)
kam-325i
Post Fri Oct 20, 2006 4:34 pm
The holes in the crankshaft pulley sound like balancing holes.......
Post Fri Oct 20, 2006 7:56 pm
Its not done (correctly) by marks, there is a plate that bolts to the back of the head that locks the cams in timing position and a crank locking pin
