little help needed please. supercharger.
ackerley
Post Wed Oct 18, 2006 11:04 am
im thinking about putting a supercharger on my car. and changing it to a carb instead of fuel injection.
I have a 1989 318i auto. I have seen a weber carb for a 1983 316 auto which i belive is a 1.8.
will this fit mine, if not what should i be looking for.
cheers for any help you all can give
chris
e21Jason
Post Wed Oct 18, 2006 12:38 pm
Hi
Your best to get a carb of a turbo car as the pressure can blow the seals.
Jason
michael24m
Post Wed Oct 18, 2006 12:40 pm
the carb engine should fit in no problems, easy conversion, but why go for carb? you'll also need the manual gearbox, and cutting down the electrics.
...lots of fiddeling and tuning with the carb engine...
Ant
Retired Team Member
Retired Team Member
Post Wed Oct 18, 2006 2:43 pm
the carb will be from an M10 engine, yours will have the M40 engine, the intake is totally wrong
in short, its a non started.
for S/C or turbo you're better retaining the EFI dude, the ignition timing will require some mods to prevent detonantion
HTH
michael24m
Post Wed Oct 18, 2006 2:50 pm
oh sorry, now i realised, you want only to fit the carb body?
i tought you ment swaping the whole engine with the carburetor one.swaping the m40 with the m10
Ant
Retired Team Member
Retired Team Member
Post Wed Oct 18, 2006 2:56 pm
now thats a good plan !, I'd still use EFI though, M10 on some bike Tb's with Ms and a supercharger.
Mmmmmmmmmmmmmmmmm
ackerley
Post Wed Oct 18, 2006 3:48 pm
what sort of mods would i need to do.
ive been out today asking if places can can sort the fuel injection to work with the super charger instead of changing to carb but ive had no results.
cheers
Ant
Retired Team Member
Retired Team Member
Post Wed Oct 18, 2006 7:09 pm
well we bin the motronic and use a standalone ECU to run the beast dude
the clue is in my signature text :wink: do a forum search on Megasquirt, will throw up most of the answers you're looking for :thumb:
ackerley
Post Wed Oct 18, 2006 7:27 pm
so all i need to get is the supercharger and the magasquirt ecu??
what about fitting the supercharger, is there a kit out there (ive had a look but cant find anything) or is it a diy job.
im thinking on using one from the mini cooper s (think its an eaton 45 or somthing)
what sort of money will i be looking for a megasquirt ecu?
DaveD
E30Zone Wiki Specialist
Post Thu Oct 19, 2006 7:49 am
go looking on http://www.e30tech.com for advice about supercharging...no one seems to like the mini one as they say its too small
have a look on this thread as well
