fuse no:10 keeps blowing!!!!
SHAZ325iSPORT
ropeman
- Avid Zone reader
Put a bigger one in
................. actually best not! I take it you've double checked all of the wiring?
xedman
Shaz,
if you have checked all the wiring then it could either be the
reverse light switch or the glovebox light that is the problem
Xed
Xed
fowler
- Boost Junkie
reverse ligt swich as it rubs on the metal past the rubber gear gaitor
on the way into the car
EX A-Tech Workshop bitch !!!
gone but not forgotten
cliffybabe
- Powered by Nelly
good call fella, like when my reverse wire got tangle around the drive sharft and got ripped offfowler wrote:reverse ligt swich as it rubs on the metal past the rubber gear gaitor
fowler
- Boost Junkie
yes mate fuse ten cotrols alot of stuff if ican rember right but that is useally the main culprit
Pull up the gearlever gaiter from the console, and find a white two pin plug and socket lying loose at the right hand side of the bottom of the lever. Pull this up, and unplug it.
Drive the car like this, and see if the fuse blowing stops.
blingsta
- Boost Junkie
also happened to me shaz, it was a short from the glove box light mate...
You have a very strange wiring loom in your car if fuse 10 is anything to do with the glovebox light!blingsta wrote:also happened to me shaz, it was a short from the glove box light mate...
e30bemer
- Nutters
320iAN
i also had a problem with fuse 10, turned out to be a short from the electric arieal the coil had snapped and the motor kept running, swapped it for an good ole fashion pull up one
e30bemer
- Nutters
320iAN
i just wouldn't pay the money that halfrauds wanted for a leccy one.e30bemer wrote:i had a pull up one, then my cousin fell against my car while pissed and snapped it in half, hence the upgrade to electric!
after i changed it i found a spare elec one in my shed for a mitsubishi
DooH!!
Electric aerial should be on 28 - definitely not on 10!320iAN wrote:i also had a problem with fuse 10, turned out to be a short from the electric arieal the coil had snapped and the motor kept running, swapped it for an good ole fashion pull up one
Check that fuse 10 is 7.5A; no bigger.
