Hi All
As you may well know, 318i's only have a single tone horn, which I find quite embaressing!
Just wondering if I buy the second deeper tone horn, how do I wire it/mount it to the car?
Apparently it goes above the front fog lamps?
Any help much appreciated
Sam
Fitting Twin tone horns
The double horn set up on an E30 uses a different main car body wiring loom and a different bodyshell, so I doubt if you'll be fitting them in an OE manner.
Easiest way is to stick both horns on the same stud behind the grill in a sort of inverted V arrangement, and just wire them in parallel.
samr
Many thanks for your advice Brianmooooooooore
320Touring
slightly off topic, but any advice to sort the "dying cow" horn on my newly aquired iS?
There's a stopped up hole with an adjuster in it on top of the horn, which may bring it back to life for a while, but I've never found it very successful as a long term fix.320Touring wrote:slightly off topic, but any advice to sort the "dying cow" horn on my newly aquired iS?
stevo
must better than my road runner effort! meep320Touring wrote:slightly off topic, but any advice to sort the "dying cow" horn on my newly aquired iS?
go to the scrappy's and get a twin tone off a modern rep mobile, they seem to have good uns!
New OE horns from BMW aren't particularly expensive, IIRC.
320Touring
you'll hear it on sundaystevo wrote:must better than my road runner effort! meep320Touring wrote:slightly off topic, but any advice to sort the "dying cow" horn on my newly aquired iS?
I fancy a dukes o hazzard one
