Hi Guys, was just having a look through some old bookmarks on my PC when I found a site that talks about fitting a keyless entry system in an E30, it's obvious that the guy in question is not in the UK, so have checked out Maplins and found a keyless entry system for Ԛ£21.99, was just wondering
A) if this is a suitable system
B) Reading his post it mentions the battery in the boot, any conflicts there?
C) How easy to install and could I follow his lead regarding location & wiring?
The guide is here:
http://zoso.no-ip.org/318i-ke.html
The Maplins product is here:
http://www.maplin.co.uk/Module.aspx?Mod ... Y&doy=4m10
Thanks in advance
Red D
Keyless Entry Installing
reddevil
The place to fit a module is above the glovebox. The central locking wires you need go across the glovebox heading for the passenger door socket behind the footwell speaker.
The wires you need are : yellow/blue - earth momentarily to lock; and green/blue - earth momentarily to unlock.
If the module flashes the indicators as well, then these are blue/red and blue/black, both on a large multipin plug and socket at the back left of the glovebox.
Looked at the link now! Your car doesn't have central locking?
If not, don't make things difficult by fixing aftermarket crap, when a quality ststem is available from nearly every scrapped E30 in the country.
eko
- Old timer
I thought all E30`s had central locking?
No, a lot of pre 87's didnt have it.
Same as electric windows.
gcorky
- Boost Junkie
reddevil
Hiya, yes, I DO have central locking, just not remote, so it would just be adding the remote unit to the existing system.
Red D
Red D
If you already have central locking, then the Maplin link is just an aftermarket replica of what you already have, although other things in Maplin's range will do what you want.
I suggest you ignore the first link. It would work, but the best place is above the glovebox. Every wire you need to install a complete alarm/entry system is available in this area.
yz_250
my car got electric mirors but not electric windows .....stupid dont you think .....lol
Think on how meny times i used my electric mirrors ?
lol twich in about 4 years
how meny times i hade to whip that lil lever for the windows manualy
lol every single day
LMAO
LMAO
"Sorry under the influence of driving in style"
FESI
Brian do you know are the wires for pre-facelift models the same as you mentioned for keyless entry or is it different. mine is 87 pre-FL
thanks
thanks
Sorry, I don't have any experience or any wiring diagrams of pre facelift stuff.FESI wrote:Brian do you know are the wires for pre-facelift models the same as you mentioned for keyless entry or is it different. mine is 87 pre-FL
thanks
